Salta al contenuto principale
How to Restore Harmonica Reeds
Cosa ti serve
  1. How to Restore Harmonica Reeds, How to Restore Harmonica Reeds: passo 1, immagine 1 di 3 How to Restore Harmonica Reeds, How to Restore Harmonica Reeds: passo 1, immagine 2 di 3 How to Restore Harmonica Reeds, How to Restore Harmonica Reeds: passo 1, immagine 3 di 3
    • Remove the 8mm Phillips #1 screws on each end of the Harmonica holding the cover plates in place and set these aside.
    • The screws come in pairs so make sure that 4 screws are recovered.
    • Set aside both the top and bottom cover plates
  2. How to Restore Harmonica Reeds: passo 2, immagine 1 di 3 How to Restore Harmonica Reeds: passo 2, immagine 2 di 3 How to Restore Harmonica Reeds: passo 2, immagine 3 di 3
    • Using the Phillips head screwdriver, remove the 11 mm Phillips #1 screws in the center of the Harmonica holding the reed plates in place and set these aside.
    • Separate the reed plates from the comb and set the comb aside.
    • Note the orientation of the reeds and which direction they face as you you set them aside. Referencing how they align with the comb will also be helpful when putting everything back together.
  3. How to Restore Harmonica Reeds: passo 3, immagine 1 di 2 How to Restore Harmonica Reeds: passo 3, immagine 2 di 2
    • In a bowl large enough to fit both reed plates, fill with water and a few drops of vinegar.
    • Place and leave the reed plates in the solution for 30 minutes.
    • This, and the following step, will serve to ensure the reeds are clear of debris for the fix and to keep your harmonica hygienic for safe operation.
  4. How to Restore Harmonica Reeds: passo 4, immagine 1 di 1
    • Remove the reed plates from the solution and use a soft brush to clear away debris.
    • When brushing reeds, it is important to brush in an up and down motion following the direction of the reeds. Failing to do so could cause unnecessary damage to the reeds.
    • Rinse the plates and allow them to dry.
  5. How to Restore Harmonica Reeds: passo 5, immagine 1 di 2 How to Restore Harmonica Reeds: passo 5, immagine 2 di 2
    • With the reeds on the reed plate facing upward, use a thin implement (such as a knife) to prop up the warped reed.
    • Use the flat head screwdriver to gently bend the reed into uniformity.
    • This process can take time and requires patience in order to keep the reeds from further damage.
    • The end product should be a roughly straight reed that just barely hovers over the cavity below.
  6. How to Restore Harmonica Reeds: passo 6, immagine 1 di 2 How to Restore Harmonica Reeds: passo 6, immagine 2 di 2
    • Place the reed plates back onto the comb and use the 8mm Phillips #1 screws to fasten them in place.
    • Do the same with the cover plates (the numbers on the plates should be in line with the holes) using the 11mm Phillips #1 screws.
    • Test to ensure that the restoration was successful.
    • If the reed was on the uppermost plate, test by blowing. Otherwise, test by drawing breath.
Linea Traguardo
Timothy Marroquin
Membro da: 08/24/23
145 Reputazione
1 Guida realizzata
0 Commenti
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 4
Ultimi 30 Giorni: 33
Tutti i Tempi: 147
