Salta al contenuto principale
How to Reset a Gigabyte GA-Z97X-Gaming 5 Motherboard
Cosa ti serve
  1. How to Reset a Gigabyte GA-Z97X-Gaming 5 Motherboard, How to Reset a Gigabyte GA-Z97X-Gaming 5 Motherboard: passo 1, immagine 1 di 1
    • Unplug the computer from the power supply before disassembly.
    • Wait 5 minutes after the device has been powered off.
  2. How to Reset a Gigabyte GA-Z97X-Gaming 5 Motherboard: passo 2, immagine 1 di 3 How to Reset a Gigabyte GA-Z97X-Gaming 5 Motherboard: passo 2, immagine 2 di 3 How to Reset a Gigabyte GA-Z97X-Gaming 5 Motherboard: passo 2, immagine 3 di 3
    • Using a Phillips #1 screwdriver, remove two screws that would grant access to inner components of your computer.
    • Remove the side panel of the computer tower to access the inner components. Slide the panel then lift it to safely remove it.
    • Removing the panel may be different for your computer.
  3. How to Reset a Gigabyte GA-Z97X-Gaming 5 Motherboard: passo 3, immagine 1 di 3 How to Reset a Gigabyte GA-Z97X-Gaming 5 Motherboard: passo 3, immagine 2 di 3 How to Reset a Gigabyte GA-Z97X-Gaming 5 Motherboard: passo 3, immagine 3 di 3
    • Using the Phillips #1 screwdriver, remove the screw holding the graphics card (GPU) onto the motherboard.
    • Disconnect any power cables that may be attached to your graphics card.
    • Carefully slide the graphics card out from its slot.
  4. How to Reset a Gigabyte GA-Z97X-Gaming 5 Motherboard: passo 4, immagine 1 di 2 How to Reset a Gigabyte GA-Z97X-Gaming 5 Motherboard: passo 4, immagine 2 di 2
    • Remove the CMOS Battery using a plastic opening tool.
    • There may be a spring mechanism available to use to easily remove the battery.
  5. How to Reset a Gigabyte GA-Z97X-Gaming 5 Motherboard: passo 5, immagine 1 di 1
    • Wait 5 minutes to allow enough time for the power to cycle through.
  6. How to Reset a Gigabyte GA-Z97X-Gaming 5 Motherboard: passo 6, immagine 1 di 1
    • Insert battery back into position with the flat side facing upwards.
Conclusione
Altre 2 persone hanno completato questa guida.
0 Commenti
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 2
Ultimi 7 Giorni: 23
Ultimi 30 Giorni: 147
Tutti i Tempi: 4,446
