Salta al contenuto principale
How to Replace the Propane Tank on a Toyota Forklift 8FGCU15
  1. How to Replace the Propane Tank on a Toyota Forklift 8FGCU15, Propane Tank: passo 1, immagine 1 di 3 How to Replace the Propane Tank on a Toyota Forklift 8FGCU15, Propane Tank: passo 1, immagine 2 di 3 How to Replace the Propane Tank on a Toyota Forklift 8FGCU15, Propane Tank: passo 1, immagine 3 di 3
    • Put the shifter in neutral, turn the engine off, and engage the emergency brake.
  2. How to Replace the Propane Tank on a Toyota Forklift 8FGCU15: passo 2, immagine 1 di 2 How to Replace the Propane Tank on a Toyota Forklift 8FGCU15: passo 2, immagine 2 di 2
    • Put on the gloves and goggles.
    • Turn the shut off valve clockwise to close the empty tank.
  3. How to Replace the Propane Tank on a Toyota Forklift 8FGCU15: passo 3, immagine 1 di 2 How to Replace the Propane Tank on a Toyota Forklift 8FGCU15: passo 3, immagine 2 di 2
    • Disconnect the truck’s gas hose from the tank’s forklift adapter.
  4. How to Replace the Propane Tank on a Toyota Forklift 8FGCU15: passo 4, immagine 1 di 3 How to Replace the Propane Tank on a Toyota Forklift 8FGCU15: passo 4, immagine 2 di 3 How to Replace the Propane Tank on a Toyota Forklift 8FGCU15: passo 4, immagine 3 di 3
    • Look at the rack securing the tank to the truck.
    • Push in the latch on the left-hand side while simultaneously pulling the entire rack back towards you.
    • This allows the rack to swing out from the truck, creating space for you to release the much larger latch holding the tank to the rack.
  5. How to Replace the Propane Tank on a Toyota Forklift 8FGCU15: passo 5, immagine 1 di 3 How to Replace the Propane Tank on a Toyota Forklift 8FGCU15: passo 5, immagine 2 di 3 How to Replace the Propane Tank on a Toyota Forklift 8FGCU15: passo 5, immagine 3 di 3
    • Release the latch holding the tank to the rack.
  6. How to Replace the Propane Tank on a Toyota Forklift 8FGCU15: passo 6, immagine 1 di 3 How to Replace the Propane Tank on a Toyota Forklift 8FGCU15: passo 6, immagine 2 di 3 How to Replace the Propane Tank on a Toyota Forklift 8FGCU15: passo 6, immagine 3 di 3
    • Remove the empty tank.
  7. How to Replace the Propane Tank on a Toyota Forklift 8FGCU15: passo 7, immagine 1 di 2 How to Replace the Propane Tank on a Toyota Forklift 8FGCU15: passo 7, immagine 2 di 2
    • Position the new tank in the rack so that the forklift adapter is facing away from you.
    • This is to make sure the adapter and gas hose will line up once the rack is reconnected to the truck.
    • If needed, rotate the latch clockwise/counterclockwise before closing to loosen/ tighten the latch.
    • Some tanks may vary in width.
  8. How to Replace the Propane Tank on a Toyota Forklift 8FGCU15: passo 8, immagine 1 di 3 How to Replace the Propane Tank on a Toyota Forklift 8FGCU15: passo 8, immagine 2 di 3 How to Replace the Propane Tank on a Toyota Forklift 8FGCU15: passo 8, immagine 3 di 3
    • Clamp the tank to the rack.
  9. How to Replace the Propane Tank on a Toyota Forklift 8FGCU15: passo 9, immagine 1 di 2 How to Replace the Propane Tank on a Toyota Forklift 8FGCU15: passo 9, immagine 2 di 2
    • Secure the rack to the truck.
  10. How to Replace the Propane Tank on a Toyota Forklift 8FGCU15: passo 10, immagine 1 di 3 How to Replace the Propane Tank on a Toyota Forklift 8FGCU15: passo 10, immagine 2 di 3 How to Replace the Propane Tank on a Toyota Forklift 8FGCU15: passo 10, immagine 3 di 3
    • Carefully screw the gas hose onto the forklift adapter.
    • It is important to keep the hose and adapter straight while tightening. If the alignment is askew, the hose will not tighten all the way and may cause liquid propane to leak from the tank once opened. This can potentially cause frostbite if in prolonged contact with bare skin.
    • Please be sure to wear the required PPE to protect your hands and eyes in case of leakage.
  11. How to Replace the Propane Tank on a Toyota Forklift 8FGCU15: passo 11, immagine 1 di 1
    • Once you are sure the connection is secure, turn the shut off valve counterclockwise to open the tank.
  12. How to Replace the Propane Tank on a Toyota Forklift 8FGCU15: passo 12, immagine 1 di 1
    • Crank up the forklift.
Conclusione
If done properly, there should be no drips or hissing, and little to no smell of propane. The engine should start at once.
Un commento
Step 11a rotate the tank so the pin and small round hole align (facing downward). The pressure relief valve must face upwards.
In case of exposure to high heat or flame the pressure relief valve will release excessive pressure.
Thomas Manby - Replica
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 6
Ultimi 7 Giorni: 19
Ultimi 30 Giorni: 77
Tutti i Tempi: 1,989
