Salta al contenuto principale
How to Replace a Watch Strap
Cosa ti serve
  1. How to Replace a Watch Strap, Watch Strap: passo 1, immagine 1 di 1
    • Begin by laying a soft towel or fabric on a table.
    • This will prevent accidental scratches during the repair.
    • We will be performing all repairs from the back of the watch, to avoid scratching the visible watch face.
  2. How to Replace a Watch Strap: passo 2, immagine 1 di 2 How to Replace a Watch Strap: passo 2, immagine 2 di 2
    • Before you begin, consider practicing with your tool to compress the bar.
    • Hold the watch with the face in your palm, with one end of the strap free to move.
  3. How to Replace a Watch Strap: passo 3, immagine 1 di 2 How to Replace a Watch Strap: passo 3, immagine 2 di 2
    • Insert your Spring Bar tool into the gap between the end of the watch strap and the watch body.
    • Press down and compress the spring. By pushing the bar away from the body, one end of the spring bar should come loose.
  4. How to Replace a Watch Strap: passo 4, immagine 1 di 2 How to Replace a Watch Strap: passo 4, immagine 2 di 2
    • Being cautious as to not damage the body or spring bar, slide the bar out from its hole and remove the strap.
    • Set this half of the strap with the spring bar aside until we remove the other strap.
  5. How to Replace a Watch Strap: passo 5, immagine 1 di 3 How to Replace a Watch Strap: passo 5, immagine 2 di 3 How to Replace a Watch Strap: passo 5, immagine 3 di 3
    • Repeat steps 2-4 to remove the other end of the watch strap.
  6. How to Replace a Watch Strap: passo 6, immagine 1 di 3 How to Replace a Watch Strap: passo 6, immagine 2 di 3 How to Replace a Watch Strap: passo 6, immagine 3 di 3
    • Replace the old or damaged watch straps by simply sliding the spring bars out and into the new straps
    • Be careful not to put the new straps on the wrong side of the body.
  7. How to Replace a Watch Strap: passo 7, immagine 1 di 3 How to Replace a Watch Strap: passo 7, immagine 2 di 3 How to Replace a Watch Strap: passo 7, immagine 3 di 3
    • Begin the reassembly by sliding the bottom of the spring bar into its hole on the watch body.
    • Remember, always work from the back of the watch to prevent visible scratches.
    • Using your spring bar tool, compress the bar and slide back into place.
    • The spring bar should click when installed correctly.
  8. How to Replace a Watch Strap: passo 8, immagine 1 di 3 How to Replace a Watch Strap: passo 8, immagine 2 di 3 How to Replace a Watch Strap: passo 8, immagine 3 di 3
    • Repeat step 7 on the other side of the watch.
    • Give the watch a tug to make sure all parts are installed correctly.
Conclusione
You have completed the fix! We hope this guide has helped.
Altre 5 persone hanno completato questa guida.
Cal Poly, Team 14-2, Green Fall 2015 Membro di Cal Poly, Team 14-2, Green Fall 2015
CPSU-GREEN-F15S14G2
4 Membri
8 Guide realizzate
0 Commenti
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 3
Ultimi 7 Giorni: 13
Ultimi 30 Giorni: 65
Tutti i Tempi: 10,646
