Salta al contenuto principale
How to Replace a Transition Strip (T Molding)
Cosa ti serve
  1. How to Replace a Transition Strip (T Molding), Transition Strip (T Molding): passo 1, immagine 1 di 1
    • Measure the exact width of the doorway using a tape measure.
  2. How to Replace a Transition Strip (T Molding): passo 2, immagine 1 di 3 How to Replace a Transition Strip (T Molding): passo 2, immagine 2 di 3 How to Replace a Transition Strip (T Molding): passo 2, immagine 3 di 3
    • Mark the T molding based on the doorway measure.
    • Cut the T molding using a sharp saw (table saw).
    • Cutting the T molding can be done for free at the place of purchase.
    • If you don't have access to a sharp saw, cut the T molding using a jigsaw and use sanding paper to soften the end.
  3. How to Replace a Transition Strip (T Molding): passo 3, immagine 1 di 3 How to Replace a Transition Strip (T Molding): passo 3, immagine 2 di 3 How to Replace a Transition Strip (T Molding): passo 3, immagine 3 di 3
    • Remove the old T molding.
    • You can use a pry bar to loosen the T molding.
  4. How to Replace a Transition Strip (T Molding): passo 4, immagine 1 di 2 How to Replace a Transition Strip (T Molding): passo 4, immagine 2 di 2
    • Use a utility knife to remove all the glue or any material used to keep the old T molding in place.
    • You may use a scraper instead of a utility knife.
    • Clean up the area thoroughly.
  5. How to Replace a Transition Strip (T Molding): passo 5, immagine 1 di 1
    • Apply the glue evenly to the gap.
  6. How to Replace a Transition Strip (T Molding): passo 6, immagine 1 di 3 How to Replace a Transition Strip (T Molding): passo 6, immagine 2 di 3 How to Replace a Transition Strip (T Molding): passo 6, immagine 3 di 3
    • Insert the T molding into the gap.
    • Press the T molding firmly onto the ground.
    • No gap should exist between the T molding and the floorings.
  7. How to Replace a Transition Strip (T Molding): passo 7, immagine 1 di 2 How to Replace a Transition Strip (T Molding): passo 7, immagine 2 di 2
    • Tape the T molding onto the floor.
    • This step ensures the T molding stays in place until the glue dries.
    • Wait 24 hours for the glue to dry.
    • Remove the tapes.
Conclusione
Rojean Noorinayer
Membro da: 05/12/21
145 Reputazione
1 Guida realizzata
0 Commenti
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 3
Ultimi 7 Giorni: 28
Ultimi 30 Giorni: 155
Tutti i Tempi: 4,500
