Salta al contenuto principale
How to Replace a Cabinet Door
Cosa ti serve
  1. How to Replace a Cabinet Door, Cabinet Door: passo 1, immagine 1 di 1
    • Using a screwdriver, either a Flathead or a Phillips, remove the screws starting from the bottom of the door all the way to the top of the door to prevent the door from swinging.
  2. How to Replace a Cabinet Door: passo 2, immagine 1 di 1
    • Next using a screwdriver, remove the screws attaching the hinge to the door.
  3. How to Replace a Cabinet Door: passo 3, immagine 1 di 3 How to Replace a Cabinet Door: passo 3, immagine 2 di 3 How to Replace a Cabinet Door: passo 3, immagine 3 di 3
    • Place the new cabinet on a flat surface. Then line up the old (or new) hinge's to holes on the door.
  4. How to Replace a Cabinet Door: passo 4, immagine 1 di 3 How to Replace a Cabinet Door: passo 4, immagine 2 di 3 How to Replace a Cabinet Door: passo 4, immagine 3 di 3
    • Finally, line up the hinge’s holes with the holes from the previous cabinet door. Then screw the new door on.
Conclusione
To reassemble your cabinet, follow these instructions in reverse order.
Texas Tech, Team 22-7, Rauch Spring 2016 Membro di Texas Tech, Team 22-7, Rauch Spring 2016
TTU-RAUCH-S16S22G7
3 Membri
2 Guide realizzate
0 Commenti
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 2
Ultimi 7 Giorni: 18
Ultimi 30 Giorni: 48
Tutti i Tempi: 1,323
