Salta al contenuto principale
How to Replace a Broken Lanyard Clasp
Cosa ti serve
  1. How to Replace a Broken Lanyard Clasp, Clasp: passo 1, immagine 1 di 3 How to Replace a Broken Lanyard Clasp, Clasp: passo 1, immagine 2 di 3 How to Replace a Broken Lanyard Clasp, Clasp: passo 1, immagine 3 di 3
    • Use a seam ripper to carefully rip the seam holding the existing clasp.
  2. How to Replace a Broken Lanyard Clasp: passo 2, immagine 1 di 3 How to Replace a Broken Lanyard Clasp: passo 2, immagine 2 di 3 How to Replace a Broken Lanyard Clasp: passo 2, immagine 3 di 3
    • Remove the existing clasp from the lanyard.
    • Use thread nippers to remove any remaining strings or fraying edges from the lanyard.
    • Make sure to trim as close to the base of the lanyard as possible without cutting into the main material.
  3. How to Replace a Broken Lanyard Clasp: passo 3, immagine 1 di 3 How to Replace a Broken Lanyard Clasp: passo 3, immagine 2 di 3 How to Replace a Broken Lanyard Clasp: passo 3, immagine 3 di 3
    • Using a tape measure, measure out 24 inches (2 ft) of your choice of thread.
    • Snip the thread at the correct length with thread nippers.
    • Use as much thread as you think is necessary, keep in mind that a larger amount of thread can be tangled more easily.
  4. How to Replace a Broken Lanyard Clasp: passo 4, immagine 1 di 2 How to Replace a Broken Lanyard Clasp: passo 4, immagine 2 di 2
    • Feed one end of the cut thread through the eye of the needle.
    • Sometimes licking the end of the thread can make it easier to thread through the needle.
  5. How to Replace a Broken Lanyard Clasp: passo 5, immagine 1 di 1
    • Pull the thread through the needle until the needle sits directly in the middle of the thread.
  6. How to Replace a Broken Lanyard Clasp: passo 6, immagine 1 di 3 How to Replace a Broken Lanyard Clasp: passo 6, immagine 2 di 3 How to Replace a Broken Lanyard Clasp: passo 6, immagine 3 di 3
    • With the lower part of the thread, cross both sides over each other.
    • Tie the two sides together, making sure the knot stays towards the bottom of the thread.
  7. How to Replace a Broken Lanyard Clasp: passo 7, immagine 1 di 3 How to Replace a Broken Lanyard Clasp: passo 7, immagine 2 di 3 How to Replace a Broken Lanyard Clasp: passo 7, immagine 3 di 3
    • Line up both sides of the lanyard.
    • Place the joined ends through the bottom of the new clasp.
    • Fold the lanyard over the bottom of the clasp.
    • Different lanyards may be configured differently. Follow the previous fold lines on your lanyard to best note how to rejoin the ends.
  8. How to Replace a Broken Lanyard Clasp: passo 8, immagine 1 di 2 How to Replace a Broken Lanyard Clasp: passo 8, immagine 2 di 2
    • Take the threaded needle and poke it through on one side of the lanyard.
    • Pull the needle and thread all the way through until the knot catches on the underside of the lanyard.
    • Make sure your needle goes through all the layers of the lanyard, paying particular attention to include the folded part.
  9. How to Replace a Broken Lanyard Clasp: passo 9, immagine 1 di 3 How to Replace a Broken Lanyard Clasp: passo 9, immagine 2 di 3 How to Replace a Broken Lanyard Clasp: passo 9, immagine 3 di 3
    • Push the needle back down through all layers of the lanyard.
    • Pull all the way through until the thread is tight.
    • Continue moving back and forth across the lanyard until you reach the other end.
    • Keep the stitches as close together as possible for better stability.
  10. How to Replace a Broken Lanyard Clasp: passo 10, immagine 1 di 1
    • Leave enough thread to comfortably tie a knot, so avoid cutting it too close to the lanyard.
    • Clip the thread in the middle of the remaining length.
    • Make sure you place your needle in a safe place now that is it free from the thread.
  11. How to Replace a Broken Lanyard Clasp: passo 11, immagine 1 di 3 How to Replace a Broken Lanyard Clasp: passo 11, immagine 2 di 3 How to Replace a Broken Lanyard Clasp: passo 11, immagine 3 di 3
    • Cross the edges of the thread still attached to the lanyard.
    • Tie them together, making sure to tighten them down to the lanyard.
    • Repeat this a couple more times to ensure it won't come undone.
  12. How to Replace a Broken Lanyard Clasp: passo 12, immagine 1 di 1
    • Clip the remaining thread.
    • The stitching should be secure so cut closely to the knot on the end.
  13. How to Replace a Broken Lanyard Clasp: passo 13, immagine 1 di 1
    • All done! Enjoy your new lanyard clasp.
Linea Traguardo
Keely Hunt
Membro da: 01/30/24
217 Reputazione
1 Guida realizzata
UC Davis, Team 2-6, Andersen Winter 2024 Membro di UC Davis, Team 2-6, Andersen Winter 2024
UCD-ANDERSEN-W24S2G6
3 Membri
1 Guida realizzata
0 Commenti
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 6
Ultimi 7 Giorni: 20
Ultimi 30 Giorni: 74
Tutti i Tempi: 145
