Salta al contenuto principale
How to Replace a 2017 Honda HR-V Smart Key Battery
Cosa ti serve
  1. How to Replace a 2017 Honda HR-V Smart Key Battery, Opening key fob: passo 1, immagine 1 di 3 How to Replace a 2017 Honda HR-V Smart Key Battery, Opening key fob: passo 1, immagine 2 di 3 How to Replace a 2017 Honda HR-V Smart Key Battery, Opening key fob: passo 1, immagine 3 di 3
    • Turn key over so "H" is in your view.
    • Swipe the small switch below the "H" to the right while holding the key with both hands.
  2. How to Replace a 2017 Honda HR-V Smart Key Battery, Taking key out of key fob: passo 2, immagine 1 di 3 How to Replace a 2017 Honda HR-V Smart Key Battery, Taking key out of key fob: passo 2, immagine 2 di 3 How to Replace a 2017 Honda HR-V Smart Key Battery, Taking key out of key fob: passo 2, immagine 3 di 3
    • Slide the valet key out from the remote.
    • Insert the valet key in between the two black rectangles on the edge of the remote.
    • Turn the key to the right to pry the two parts open.
  3. How to Replace a 2017 Honda HR-V Smart Key Battery, Taking battery out: passo 3, immagine 1 di 3 How to Replace a 2017 Honda HR-V Smart Key Battery, Taking battery out: passo 3, immagine 2 di 3 How to Replace a 2017 Honda HR-V Smart Key Battery, Taking battery out: passo 3, immagine 3 di 3
    • The valet key shell will split into two parts.
    • Using minimal force take the battery out with your finger or a plastic prying tool.
    • Lift the battery out.
  4. How to Replace a 2017 Honda HR-V Smart Key Battery, Replacing battery: passo 4, immagine 1 di 3 How to Replace a 2017 Honda HR-V Smart Key Battery, Replacing battery: passo 4, immagine 2 di 3 How to Replace a 2017 Honda HR-V Smart Key Battery, Replacing battery: passo 4, immagine 3 di 3
    • Insert the new battery by putting the bottom of battery in big teeth first.
    • Push the top of the battery into place.
  5. How to Replace a 2017 Honda HR-V Smart Key Battery, Putting key fob back together: passo 5, immagine 1 di 2 How to Replace a 2017 Honda HR-V Smart Key Battery, Putting key fob back together: passo 5, immagine 2 di 2
    • Push the two halves of the key together.
    • Align the edges and seal it in place by pressing the sides of the shell together.
  6. How to Replace a 2017 Honda HR-V Smart Key Battery, Inserting key back into key fob: passo 6, immagine 1 di 2 How to Replace a 2017 Honda HR-V Smart Key Battery, Inserting key back into key fob: passo 6, immagine 2 di 2
    • Insert the valet key back into the designated slot opposite of the silver loop.
    • Smart key battery is replaced and ready to use!
Conclusione
Altre 4 persone hanno completato questa guida.
Un commento
Easy-to-use guide, I didn't even know that there was a key inside of the fob...Great demo on a do it yourself and save yourself money that is needed else where...Thank you for sharing....
Jannette Needs - Replica
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 40
Ultimi 7 Giorni: 268
Ultimi 30 Giorni: 1,052
Tutti i Tempi: 14,768
