Salta al contenuto principale
How to Replace Velcro on a Baseball Cap
Cosa ti serve
  1. How to Replace Velcro on a Baseball Cap, How to Replace Velcro on a Baseball Cap: passo 1, immagine 1 di 3 How to Replace Velcro on a Baseball Cap, How to Replace Velcro on a Baseball Cap: passo 1, immagine 2 di 3 How to Replace Velcro on a Baseball Cap, How to Replace Velcro on a Baseball Cap: passo 1, immagine 3 di 3
    • Use a seam ripper to remove the stitching between the velcro and the hat.
    • Make sure to fully remove the velcro by also seam ripping the fold inside the hat.
    • Repeat this step on the other strap.
  2. How to Replace Velcro on a Baseball Cap: passo 2, immagine 1 di 2 How to Replace Velcro on a Baseball Cap: passo 2, immagine 2 di 2
    • Use a measuring tape to measure how much velcro you will need.
  3. How to Replace Velcro on a Baseball Cap: passo 3, immagine 1 di 1
    • Cut the precise amount of velcro to be sewn onto the hat.
  4. How to Replace Velcro on a Baseball Cap: passo 4, immagine 1 di 1
    • Pin the new velcro onto the hat.
    • This will make sure both pieces stay in place when you start to sew the velcro in place.
  5. How to Replace Velcro on a Baseball Cap: passo 5, immagine 1 di 3 How to Replace Velcro on a Baseball Cap: passo 5, immagine 2 di 3 How to Replace Velcro on a Baseball Cap: passo 5, immagine 3 di 3
    • To prepare for sewing, thread the needle with a thread color of your choice.
    • Pull the thread through the loop.
    • Measure about 24 inches
    • Make sure to leave an even amount of thread on either side of the needle.
    • 12 inches on each side
    • Cut the thread.
    • Knot the ends of the thread together to secure.
  6. How to Replace Velcro on a Baseball Cap: passo 6, immagine 1 di 3 How to Replace Velcro on a Baseball Cap: passo 6, immagine 2 di 3 How to Replace Velcro on a Baseball Cap: passo 6, immagine 3 di 3
    • Use a running stitch to secure the velcro to the strap of the cap.
    • To do a running stitch: bring the needle up through the cap side of the strap and then the velcro until the knot at the end of the thread hits the fabric.
    • At this point, bring the needle back down through the velcro a few millimeters from where you started, following the direction you're trying to sew.
    • Keep bringing the needle up and down through the strap and velcro, moving the same distance each time. Repeat this until you have sewn around the entire piece of velcro to secure it.
  7. How to Replace Velcro on a Baseball Cap: passo 7, immagine 1 di 1
    • When you come to the end, knot the thread next to the last running stitch to finish it.
  8. How to Replace Velcro on a Baseball Cap: passo 8, immagine 1 di 1
    • Repeat steps 4 - 7 on the remaining strap using the other side of the velcro.
    • Once finished, the velcro should be securely sewn on the baseball cap and ready to use.
Linea Traguardo
Vi Truong
Membro da: 10/26/18
189 Reputazione
1 Guida realizzata
UC Davis, Team S1-G9, Bender Fall 2018 Membro di UC Davis, Team S1-G9, Bender Fall 2018
UCD-BENDER-F18S1G9
3 Membri
1 Guida realizzata
0 Commenti
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 7
Ultimi 7 Giorni: 87
Ultimi 30 Giorni: 333
Tutti i Tempi: 17,447
