Salta al contenuto principale
How to Replace Hot and Cold Water Pipes for a Washer
Cosa ti serve
  1. How to Replace Hot and Cold Water Pipes for a Washer, How to Replace Hot and Cold Water Pipes for a Washer: passo 1, immagine 1 di 1
    • Before starting this guide, shut off your water to the washer and dryer. In this guide, valves are used. Some newer setups may use levers.
    • Mark the hot and cold water pipelines with a marker for proper visuals.
    • Hot water
    • Cold water
  2. How to Replace Hot and Cold Water Pipes for a Washer, Disconnect the pipes: passo 2, immagine 1 di 3 How to Replace Hot and Cold Water Pipes for a Washer, Disconnect the pipes: passo 2, immagine 2 di 3 How to Replace Hot and Cold Water Pipes for a Washer, Disconnect the pipes: passo 2, immagine 3 di 3
    • Using an adjustable wrench, disconnect the pipes carefully from the water supply side and the washer side.
    • After the pipes are disconnected, re-check the leakage and rust in the washer installation.
  3. How to Replace Hot and Cold Water Pipes for a Washer: passo 3, immagine 1 di 1
    • Rotate the adjustable wrench in a counter-clockwise direction to loosen the pipe connection.
    • Make sure to remove the old white Teflon tape. Use a bucket and a piece of cloth for water damps from the connection.
  4. How to Replace Hot and Cold Water Pipes for a Washer, Prepare the new pipes: passo 4, immagine 1 di 1
    • Set up the new pipes to be installed.
    • Check for blockage or any cracks in the valve.
  5. How to Replace Hot and Cold Water Pipes for a Washer, Wrap new Teflon tape: passo 5, immagine 1 di 1
    • Wrap the new piece of Teflon tape around the shut-off valve connection.
  6. How to Replace Hot and Cold Water Pipes for a Washer, Install the new pipes: passo 6, immagine 1 di 3 How to Replace Hot and Cold Water Pipes for a Washer, Install the new pipes: passo 6, immagine 2 di 3 How to Replace Hot and Cold Water Pipes for a Washer, Install the new pipes: passo 6, immagine 3 di 3
    • Install and connect the new pipes using an adjustable wrench.
  7. How to Replace Hot and Cold Water Pipes for a Washer, Return the water supply: passo 7, immagine 1 di 2 How to Replace Hot and Cold Water Pipes for a Washer, Return the water supply: passo 7, immagine 2 di 2
    • Rotate the pipes in a clockwise direction to tighten up.
    • Turn on the water supply. Perform a quick wash and check the connection.
Conclusione
  • This guide contains easy steps of instructions to be followed if your pipes of the washer are needed to be changed.
Jenish
Membro da: 01/22/21
169 Reputazione
1 Guida realizzata
Un commento
Those are hoses. Pipes are in the wall
NitWit - Replica
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 7
Ultimi 7 Giorni: 39
Ultimi 30 Giorni: 196
Tutti i Tempi: 7,703
