Salta al contenuto principale
How to Replace Concealed Cabinet Hinges
Cosa ti serve
  1. How to Replace Concealed Cabinet Hinges, Hinge: passo 1, immagine 1 di 3 How to Replace Concealed Cabinet Hinges, Hinge: passo 1, immagine 2 di 3 How to Replace Concealed Cabinet Hinges, Hinge: passo 1, immagine 3 di 3
    • Remove the screws that are attached to the cabinet door.
    • Unscrew the top and bottom hinges even if you are only replacing one hinge.
    • Remove the cabinet door from the hinge.
    • You may need to wiggle or pry the door off.
  2. How to Replace Concealed Cabinet Hinges: passo 2, immagine 1 di 2 How to Replace Concealed Cabinet Hinges: passo 2, immagine 2 di 2
    • Remove the screws that go into the cabinet frame from the hinge, then remove the hinge.
    • Only the hinge being replaced needs to be removed.
  3. How to Replace Concealed Cabinet Hinges: passo 3, immagine 1 di 3 How to Replace Concealed Cabinet Hinges: passo 3, immagine 2 di 3 How to Replace Concealed Cabinet Hinges: passo 3, immagine 3 di 3
    • Insert the new hinge into the cabinet door's pre-cut hole.
    • Attach the hinge with the provided screws.
    • To avoid striping the screws, do not over tighten.
  4. How to Replace Concealed Cabinet Hinges: passo 4, immagine 1 di 1
    • Reattach the cabinet door to the cabinet frame.
    • Do not tighten the screws all the way. You will need to align the door later.
    • You may need a friend to hold the door while you screw it back into place.
  5. How to Replace Concealed Cabinet Hinges: passo 5, immagine 1 di 2 How to Replace Concealed Cabinet Hinges: passo 5, immagine 2 di 2
    • Lift or lower the cabinet door to align the hinges with its original location.
    • Changes in wood stain can serve as a useful alignment guide.
    • Tighten all the screws.
  6. How to Replace Concealed Cabinet Hinges: passo 6, immagine 1 di 3 How to Replace Concealed Cabinet Hinges: passo 6, immagine 2 di 3 How to Replace Concealed Cabinet Hinges: passo 6, immagine 3 di 3
    • Use this step to adjust the amount of space between the cabinet door and the cabinet frame.
    • Loosen the adjustment screws, but do not remove them.
    • Slide the cabinet door to your desired position.
    • Tighten the screws.
  7. How to Replace Concealed Cabinet Hinges: passo 7, immagine 1 di 1
    • Use this step if your cabinet door closes too hard or does not completely close.
    • Tighten this screw to keep the cabinet door from closing too hard. Loosen the screw to allow the cabinet door to close completely.
    • Do not completely remove this screw.
Linea Traguardo
Altre 4 persone hanno completato questa guida.
Naomi Frazier
Membro da: 04/28/17
171 Reputazione
1 Guida realizzata
UC Davis, Team S4-G4, Cole Spring 2017 Membro di UC Davis, Team S4-G4, Cole Spring 2017
UCD-COLE-S17S4G4
3 Membri
1 Guida realizzata
0 Commenti
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 1
Ultimi 7 Giorni: 19
Ultimi 30 Giorni: 102
Tutti i Tempi: 27,973
