Salta al contenuto principale
How to Replace Basic Bag Lining
Cosa ti serve
  1. How to Replace Basic Bag Lining, Bag Lining: passo 1, immagine 1 di 1
    • Assess the old bag lining you will be replacing.
    • Consider color, material, and amount of fabric needed for the new lining.
  2. How to Replace Basic Bag Lining: passo 2, immagine 1 di 3 How to Replace Basic Bag Lining: passo 2, immagine 2 di 3 How to Replace Basic Bag Lining: passo 2, immagine 3 di 3
    • At the seams, use your hands or sewing to carefully rip or cut out old bag lining.
  3. How to Replace Basic Bag Lining: passo 3, immagine 1 di 1
    • Lay out old bag lining on fabric and measure out the size of the new bag lining, adding an extra 2 cm on each side.
  4. How to Replace Basic Bag Lining: passo 4, immagine 1 di 2 How to Replace Basic Bag Lining: passo 4, immagine 2 di 2
    • Fold new fabric in half to create one closed end for the bag lining.
    • Cut out bag lining based on measurements from previous step.
  5. How to Replace Basic Bag Lining: passo 5, immagine 1 di 1
    • Stitch the two sides of fabric adjacent to the folded side to create a rectangle with one opening.
    • You can stitch by hand or use a sewing machine.
    • Use stitches small and tight enough to ensure new lining remains intact.
    • Finish stitching 2 cm from the end of the open side.
  6. How to Replace Basic Bag Lining: passo 6, immagine 1 di 1
    • Fold over extra 2 cm from the opening of the new bag lining outward to hide the raw edge of the fabric.
    • With a needle suitable for sewing through your bag material, attach the bag lining with a straight running stitch around the mouth of the bag.
    • See the article How to Work a Running Stitch from The Spruce Crafts to learn how to do a running stitch.
Linea Traguardo
Ijada Nguyen
Membro da: 01/26/23
133 Reputazione
1 Guida realizzata
UC Davis, Team 1-1, Morris Winter 2023 Membro di UC Davis, Team 1-1, Morris Winter 2023
UCD-MORRIS-W23S1G1
2 Membri
1 Guida realizzata
0 Commenti
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 2
Ultimi 7 Giorni: 20
Ultimi 30 Giorni: 82
Tutti i Tempi: 994
