Salta al contenuto principale
How to Repair the Lining of a Canvas Shoe with an Iron-On Patch
Cosa ti serve
  1. How to Repair the Lining of a Canvas Shoe with an Iron-On Patch, How to Repair the Lining of a Canvas Shoe with an Iron-On Patch: passo 1, immagine 1 di 1
    • Identify the hole or tear in your canvas shoe.
  2. How to Repair the Lining of a Canvas Shoe with an Iron-On Patch: passo 2, immagine 1 di 2 How to Repair the Lining of a Canvas Shoe with an Iron-On Patch: passo 2, immagine 2 di 2
    • Preheat the iron to the highest setting without steam. In most cases this will be the cotton or linen setting.
    • If your iron does not have an on/off setting for steam, make sure there is no water in the water compartment when starting the project.
    • Always exercise caution when working around a hot iron.
  3. How to Repair the Lining of a Canvas Shoe with an Iron-On Patch: passo 3, immagine 1 di 3 How to Repair the Lining of a Canvas Shoe with an Iron-On Patch: passo 3, immagine 2 di 3 How to Repair the Lining of a Canvas Shoe with an Iron-On Patch: passo 3, immagine 3 di 3
    • Unlace the shoe so you can reach the hole better.
  4. How to Repair the Lining of a Canvas Shoe with an Iron-On Patch: passo 4, immagine 1 di 2 How to Repair the Lining of a Canvas Shoe with an Iron-On Patch: passo 4, immagine 2 di 2
    • Cut away loose threads and frayed edges to leave a smooth surface for the patch to adhere to.
  5. How to Repair the Lining of a Canvas Shoe with an Iron-On Patch: passo 5, immagine 1 di 3 How to Repair the Lining of a Canvas Shoe with an Iron-On Patch: passo 5, immagine 2 di 3 How to Repair the Lining of a Canvas Shoe with an Iron-On Patch: passo 5, immagine 3 di 3
    • Measure and cut patch to slightly larger than the size of the hole, this can be eye-balled.
  6. How to Repair the Lining of a Canvas Shoe with an Iron-On Patch: passo 6, immagine 1 di 2 How to Repair the Lining of a Canvas Shoe with an Iron-On Patch: passo 6, immagine 2 di 2
    • Lay a towel down to protect your work surface while ironing.
  7. How to Repair the Lining of a Canvas Shoe with an Iron-On Patch: passo 7, immagine 1 di 2 How to Repair the Lining of a Canvas Shoe with an Iron-On Patch: passo 7, immagine 2 di 2
    • Make sure the patch is as flat as possible against the shoe.
    • Iron over the patch for 60 seconds.
    • If you see or smell any smoke, stop ironing immediately. Your iron may be too hot.
  8. How to Repair the Lining of a Canvas Shoe with an Iron-On Patch: passo 8, immagine 1 di 1
    • Roll your towel tightly so it will fit inside your shoe.
  9. How to Repair the Lining of a Canvas Shoe with an Iron-On Patch: passo 9, immagine 1 di 3 How to Repair the Lining of a Canvas Shoe with an Iron-On Patch: passo 9, immagine 2 di 3 How to Repair the Lining of a Canvas Shoe with an Iron-On Patch: passo 9, immagine 3 di 3
    • Use the rolled towel to support the shoe where you just ironed the patch.
    • Iron the location of the patch from the other side for 30 seconds.
  10. How to Repair the Lining of a Canvas Shoe with an Iron-On Patch: passo 10, immagine 1 di 1
    • Let the patch cool before use.
Conclusione
Try on your shoe. If there are edges that are not flattened, iron on a lower heat for 30 seconds on those spots. Be careful not to heat the patch too much, as the glue on the patch could dry out. Once cooled, re-lace the shoe, and it will be ready to wear again!
If you desire extra security, you can reinforce your patch using this guide.
Abigail Lodge
Membro da: 02/02/23
181 Reputazione
1 Guida realizzata
UC Davis, Team 4-3, Andersen Winter 2023 Membro di UC Davis, Team 4-3, Andersen Winter 2023
UCD-ANDERSEN-W23S4G3
3 Membri
1 Guida realizzata
0 Commenti
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 12
Ultimi 30 Giorni: 57
Tutti i Tempi: 795
