Salta al contenuto principale
How to Repair the Jump Ring on a Mask Holder
Cosa ti serve
  1. How to Repair the Jump Ring on a Mask Holder, How to Repair the Jump Ring on a Mask Holder: passo 1, immagine 1 di 1
    • Remove the broken or opened jump ring from your mask holder.
  2. How to Repair the Jump Ring on a Mask Holder: passo 2, immagine 1 di 1
    • Hold needle nose pliers with one hand and the jump ring in the other.
    • Make sure you have good light so you can see clearly.
  3. How to Repair the Jump Ring on a Mask Holder: passo 3, immagine 1 di 2 How to Repair the Jump Ring on a Mask Holder: passo 3, immagine 2 di 2
    • Use the pliers to open the jump ring carefully.
  4. How to Repair the Jump Ring on a Mask Holder: passo 4, immagine 1 di 1
    • Reattach the chain to the jump ring.
  5. How to Repair the Jump Ring on a Mask Holder: passo 5, immagine 1 di 1
    • Use the pliers to close the jump ring.
  6. How to Repair the Jump Ring on a Mask Holder: passo 6, immagine 1 di 2 How to Repair the Jump Ring on a Mask Holder: passo 6, immagine 2 di 2
    • Make sure the ring is closed tightly so the mask holder stays secure.
Linea Traguardo
0 Commenti
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 6
Ultimi 30 Giorni: 12
Tutti i Tempi: 318
