Salta al contenuto principale
How to Repair the Broken Toe Strap of a Fabric Sandal
Cosa ti serve
  1. How to Repair the Broken Toe Strap of a Fabric Sandal, How to Repair the Broken Toe Strap of a Fabric Sandal: passo 1, immagine 1 di 2 How to Repair the Broken Toe Strap of a Fabric Sandal, How to Repair the Broken Toe Strap of a Fabric Sandal: passo 1, immagine 2 di 2
    • Draw a rectangle on the bottom of the sandal that centers the hole of the toe strap.
  2. How to Repair the Broken Toe Strap of a Fabric Sandal: passo 2, immagine 1 di 3 How to Repair the Broken Toe Strap of a Fabric Sandal: passo 2, immagine 2 di 3 How to Repair the Broken Toe Strap of a Fabric Sandal: passo 2, immagine 3 di 3
    • Slice through three connecting sides at the bottom of the rectangle using a box cutter.
    • Keep your fingers away from the box cutter to avoid injury.
    • Create shallow slices to avoid cutting through the sandal.
  3. How to Repair the Broken Toe Strap of a Fabric Sandal: passo 3, immagine 1 di 3 How to Repair the Broken Toe Strap of a Fabric Sandal: passo 3, immagine 2 di 3 How to Repair the Broken Toe Strap of a Fabric Sandal: passo 3, immagine 3 di 3
    • Insert a toothpick into the bottom slit.
    • Use the toothpick as a lever to wedge open the flap.
    • Use an extra toothpick if the first one breaks.
  4. How to Repair the Broken Toe Strap of a Fabric Sandal: passo 4, immagine 1 di 3 How to Repair the Broken Toe Strap of a Fabric Sandal: passo 4, immagine 2 di 3 How to Repair the Broken Toe Strap of a Fabric Sandal: passo 4, immagine 3 di 3
    • Slide the toe strap through the hole of the sandal until you feel resistance.
  5. How to Repair the Broken Toe Strap of a Fabric Sandal: passo 5, immagine 1 di 3 How to Repair the Broken Toe Strap of a Fabric Sandal: passo 5, immagine 2 di 3 How to Repair the Broken Toe Strap of a Fabric Sandal: passo 5, immagine 3 di 3
    • Flatten the toe strap against the insole of the sandal.
  6. How to Repair the Broken Toe Strap of a Fabric Sandal: passo 6, immagine 1 di 3 How to Repair the Broken Toe Strap of a Fabric Sandal: passo 6, immagine 2 di 3 How to Repair the Broken Toe Strap of a Fabric Sandal: passo 6, immagine 3 di 3
    • Apply the glue to the toe strap and inside the flap of the sandal.
    • Wear protective gloves to avoid skin irritation.
  7. How to Repair the Broken Toe Strap of a Fabric Sandal: passo 7, immagine 1 di 3 How to Repair the Broken Toe Strap of a Fabric Sandal: passo 7, immagine 2 di 3 How to Repair the Broken Toe Strap of a Fabric Sandal: passo 7, immagine 3 di 3
    • Close the sole flap.
    • Press the flap down until it is even with the sole of the sandal.
  8. How to Repair the Broken Toe Strap of a Fabric Sandal: passo 8, immagine 1 di 2 How to Repair the Broken Toe Strap of a Fabric Sandal: passo 8, immagine 2 di 2
    • Use the trigger clamp to tightly press the flap against the sandal.
  9. How to Repair the Broken Toe Strap of a Fabric Sandal: passo 9, immagine 1 di 3 How to Repair the Broken Toe Strap of a Fabric Sandal: passo 9, immagine 2 di 3 How to Repair the Broken Toe Strap of a Fabric Sandal: passo 9, immagine 3 di 3
    • Tighten the trigger clamp by squeezing the trigger.
    • Leave the trigger clamp on the sandal to dry overnight.
  10. How to Repair the Broken Toe Strap of a Fabric Sandal: passo 10, immagine 1 di 1
    • Remove the trigger clamp by pressing the quick-release button.
  11. How to Repair the Broken Toe Strap of a Fabric Sandal: passo 11, immagine 1 di 3 How to Repair the Broken Toe Strap of a Fabric Sandal: passo 11, immagine 2 di 3 How to Repair the Broken Toe Strap of a Fabric Sandal: passo 11, immagine 3 di 3
    • Pour rubbing alcohol onto a paper towel.
    • Rub the paper towel over the shoe to remove pencil marks and excess glue.
Conclusione
If you properly follow the instructions in this guide, your sandal will be repaired to a lasting, wearable condition.
Kulthum Lakha
Membro da: 09/28/21
193 Reputazione
1 Guida realizzata
0 Commenti
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 19
Ultimi 30 Giorni: 85
Tutti i Tempi: 2,675
