Salta al contenuto principale
How to Repair an Elastic Loop on a Blouse
Cosa ti serve
  1. How to Repair an Elastic Loop on a Blouse, How to Repair an Elastic Loop on a Blouse: passo 1, immagine 1 di 1
    • Place the broken elastic loop back in its original position on the blouse.
  2. How to Repair an Elastic Loop on a Blouse: passo 2, immagine 1 di 1
    • Double thread the needle.
    • Pass the needle through the base of the elastic loop.
  3. How to Repair an Elastic Loop on a Blouse: passo 3, immagine 1 di 2 How to Repair an Elastic Loop on a Blouse: passo 3, immagine 2 di 2
    • Pass the needle through the stitch line where the elastic loop was originally secured, then back through the base of the elastic loop, at least 6-7 times.
    • Don't pull the thread tight; leave a loop to tie off the thread.
    • Insert your needle through the loops, then pull the thread tight.
  4. How to Repair an Elastic Loop on a Blouse: passo 4, immagine 1 di 1
    • Simply cut the thread connected to the needle, and then any dangling threads.
Conclusione
Enjoy your revitalized garment!
0 Commenti
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 12
Ultimi 7 Giorni: 32
Ultimi 30 Giorni: 132
Tutti i Tempi: 3,572
