Salta al contenuto principale
How to Repair a Broken Jump Ring
Cosa ti serve
  1. How to Repair a Broken Jump Ring, How to Repair a Broken Jump Ring: passo 1, immagine 1 di 1
    • Firmly grasp the broken jump ring using one set of small needle-nose pliers.
    • Make sure that the ring's opening is not blocked by the pliers.
  2. How to Repair a Broken Jump Ring: passo 2, immagine 1 di 1
    • Grasp the opposite side of the jump ring with your other pair of small needle noise pliers.
  3. How to Repair a Broken Jump Ring: passo 3, immagine 1 di 1
    • Gently twist the pliers in opposite directions until the gap is wide enough to reattach the jump ring to the ear wire.
  4. How to Repair a Broken Jump Ring: passo 4, immagine 1 di 2 How to Repair a Broken Jump Ring: passo 4, immagine 2 di 2
    • Grasp the ear wire (if applicable) and insert its loop into the opening of the jump ring.
  5. How to Repair a Broken Jump Ring: passo 5, immagine 1 di 2 How to Repair a Broken Jump Ring: passo 5, immagine 2 di 2
    • Insert your earring into the opening of the jump ring.
  6. How to Repair a Broken Jump Ring: passo 6, immagine 1 di 2 How to Repair a Broken Jump Ring: passo 6, immagine 2 di 2
    • Grasp the jump ring between your two pairs of pliers and push/twist the two ends of the ring toward each other, until the two ends meet and the gap is closed.
    • Make sure that the gap is closed tight!
Conclusione
Your earrings are ready to be worn again!
0 Commenti
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 7
Ultimi 30 Giorni: 36
Tutti i Tempi: 1,030
