Salta al contenuto principale
How to Repair Warped Eyeglasses Arm Joint and Replace the Screw
Cosa ti serve
  1. How to Repair Warped Eyeglasses Arm Joint and Replace the Screw, How to Repair Warped Eyeglasses Arm Joint and Replace the Screw: passo 1, immagine 1 di 3 How to Repair Warped Eyeglasses Arm Joint and Replace the Screw, How to Repair Warped Eyeglasses Arm Joint and Replace the Screw: passo 1, immagine 2 di 3 How to Repair Warped Eyeglasses Arm Joint and Replace the Screw, How to Repair Warped Eyeglasses Arm Joint and Replace the Screw: passo 1, immagine 3 di 3
    • Select a screw from the assorted eyeglasses screws box to begin the size-fitting process.
    • Start from the smaller sizes and work your way up until the screw body fits in the eyeglass frame hinge.
  2. How to Repair Warped Eyeglasses Arm Joint and Replace the Screw: passo 2, immagine 1 di 3 How to Repair Warped Eyeglasses Arm Joint and Replace the Screw: passo 2, immagine 2 di 3 How to Repair Warped Eyeglasses Arm Joint and Replace the Screw: passo 2, immagine 3 di 3
    • Place the screw into the end piece of the eyeglasses.
    • If the screw does not fit, repeat Steps 1 and 2 until you find a match.
    • Set the screw aside once you have the perfect fit.
  3. How to Repair Warped Eyeglasses Arm Joint and Replace the Screw: passo 3, immagine 1 di 3 How to Repair Warped Eyeglasses Arm Joint and Replace the Screw: passo 3, immagine 2 di 3 How to Repair Warped Eyeglasses Arm Joint and Replace the Screw: passo 3, immagine 3 di 3
    • Position the pliers so that both sides of the arm joint are on the inside of the pliers.
    • Apply slight pressure to the pliers to bend the warped arm joint back into place.
    • Too much pressure might break the arm joint or make the arm joint too tight for the next step, so be very mindful about the pressure!
  4. How to Repair Warped Eyeglasses Arm Joint and Replace the Screw: passo 4, immagine 1 di 2 How to Repair Warped Eyeglasses Arm Joint and Replace the Screw: passo 4, immagine 2 di 2
    • Align the arm joint to the end piece of the eyeglasses.
    • If the two pieces do not align or the fit is too loose, repeat Step 3 to adjust the arm joint.
  5. How to Repair Warped Eyeglasses Arm Joint and Replace the Screw: passo 5, immagine 1 di 3 How to Repair Warped Eyeglasses Arm Joint and Replace the Screw: passo 5, immagine 2 di 3 How to Repair Warped Eyeglasses Arm Joint and Replace the Screw: passo 5, immagine 3 di 3
    Attrezzo utilizzato in questo passaggio:
    Compra
    • Place the screw through the arm joint and end piece using tweezers.
  6. How to Repair Warped Eyeglasses Arm Joint and Replace the Screw: passo 6, immagine 1 di 3 How to Repair Warped Eyeglasses Arm Joint and Replace the Screw: passo 6, immagine 2 di 3 How to Repair Warped Eyeglasses Arm Joint and Replace the Screw: passo 6, immagine 3 di 3
    • Tighten the screw with the screwdriver.
    • Depending on your eyeglasses screws, choose the appropriate screwdriver size and shape.
Conclusione
To disassemble your device, follow these instructions in reverse order.
Jaclyn Nguyen
Membro da: 02/01/23
133 Reputazione
1 Guida realizzata
UC Davis, Team 4-4, Andersen Winter 2023 Membro di UC Davis, Team 4-4, Andersen Winter 2023
UCD-ANDERSEN-W23S4G4
3 Membri
1 Guida realizzata
0 Commenti
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 3
Ultimi 7 Giorni: 14
Ultimi 30 Giorni: 68
Tutti i Tempi: 980
