Salta al contenuto principale
How to Repair Frayed Shoelaces
Cosa ti serve
  1. How to Repair Frayed Shoelaces, How to Repair Frayed Shoelaces: passo 1, immagine 1 di 1
    • Cut of the excess frayed shoelace.
  2. How to Repair Frayed Shoelaces: passo 2, immagine 1 di 3 How to Repair Frayed Shoelaces: passo 2, immagine 2 di 3 How to Repair Frayed Shoelaces: passo 2, immagine 3 di 3
    • Slip the entire heat shrink tube over the frayed part of the lace.
    • Make sure to clump the frayed part of the lace together when inserting the tubing.
    • Do not cover too much of the lace that is not frayed with tubing as that could result in unwanted indents in the shoelace.
  3. How to Repair Frayed Shoelaces: passo 3, immagine 1 di 2 How to Repair Frayed Shoelaces: passo 3, immagine 2 di 2
    • After slipping the tube on, grab the scissors and trim the excess tubing to the length of your satisfaction.
    • Remember not to go beyond the frayed part of the lace with tubing.
  4. How to Repair Frayed Shoelaces: passo 4, immagine 1 di 3 How to Repair Frayed Shoelaces: passo 4, immagine 2 di 3 How to Repair Frayed Shoelaces: passo 4, immagine 3 di 3
    • Now use the lighter and heat the heat shrink tube, about an inch away from the lace, until the tube becomes compressed all the way around.
    • Make sure to heat the heat shrink tube all the way around, heating the entire tube
    • When heating, always keep moving the lighter all around and not staying on one part of the tube for too long.
  5. How to Repair Frayed Shoelaces: passo 5, immagine 1 di 1
    • Repeat these steps on all the other frayed shoelaces.
Conclusione
When the heat shrink tube is completely shrunk to appropriate size, you are finished. Repeat steps 1-4 depending on how many frayed laces are present.
Altre 14 persone hanno completato questa guida.
Anirudh Jain
Membro da: 04/09/15
605 Reputazione
1 Guida realizzata
Cal Poly, Team 28-6, Green Spring 2015 Membro di Cal Poly, Team 28-6, Green Spring 2015
CPSU-GREEN-S15S28G6
4 Membri
10 Guide realizzate
0 Commenti
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 4
Ultimi 7 Giorni: 12
Ultimi 30 Giorni: 57
Tutti i Tempi: 11,834
