Salta al contenuto principale
How to Remove a Label From a Glass Jar
Cosa ti serve
  1. How to Remove a Label From a Glass Jar, How to Remove a Label From a Glass Jar: passo 1, immagine 1 di 1
    • Boil enough water to fill both glass jars.
    • Pour the boiling water into the smaller jar using a tea kettle.
    • The hot water will heat up the glass and melt the adhesive from the inside.
  2. How to Remove a Label From a Glass Jar: passo 2, immagine 1 di 2 How to Remove a Label From a Glass Jar: passo 2, immagine 2 di 2
    • Place the lid onto the jar and tighten.
    • This step is optional if the larger container in Step 3 has a lid.
  3. How to Remove a Label From a Glass Jar: passo 3, immagine 1 di 2 How to Remove a Label From a Glass Jar: passo 3, immagine 2 di 2
    • Place the jar into a larger glass container.
  4. How to Remove a Label From a Glass Jar: passo 4, immagine 1 di 1
    • Pour hot water into the larger jar until the water level is above the label.
  5. How to Remove a Label From a Glass Jar: passo 5, immagine 1 di 1
    • Add a few drops of dish soap into the larger jar.
    • This helps to clean up residue from the label.
  6. How to Remove a Label From a Glass Jar: passo 6, immagine 1 di 2 How to Remove a Label From a Glass Jar: passo 6, immagine 2 di 2
    • Place the lid on the larger container and tighten.
    • This prevents heat from leaving the container.
    • Let the container sit for 10 to 15 minutes or until completely cooled.
  7. How to Remove a Label From a Glass Jar: passo 7, immagine 1 di 2 How to Remove a Label From a Glass Jar: passo 7, immagine 2 di 2
    • Remove the smaller jar from the larger container.
    • Pour the water out of the jar.
    • Peel the label off of the jar.
    • For containers with loose labels, the label will fall off or be able to be slipped off.
    • Wipe off excess residue with a cloth or paper towel.
Linea Traguardo
Altre 3 persone hanno completato questa guida.
Un commento
Génial ! Je n'y avais jamais pensé. Merci beaucoup !
Josette Léost - Replica
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 0
Ultimi 30 Giorni: 23
Tutti i Tempi: 403
