Salta al contenuto principale
How to Remove Wax From Clothing
Cosa ti serve
  1. How to Remove Wax From Clothing, Removing Dried Wax: passo 1, immagine 1 di 1
    • Set up the ironing board.
    • Plug in the iron and turn it on.
    • Your iron may need some time to heat up, especially if it is an older model.
  2. How to Remove Wax From Clothing: passo 2, immagine 1 di 1
    • Place your piece of clothing onto the ironing board.
  3. How to Remove Wax From Clothing: passo 3, immagine 1 di 2 How to Remove Wax From Clothing: passo 3, immagine 2 di 2
    • Take your brown paper bag and fold it over the affected area, being sure to cover both sides of the waxy clothing.
  4. How to Remove Wax From Clothing: passo 4, immagine 1 di 1
    • Press the iron on top of the brown paper bag.
    • Move the iron around as if you are ironing wrinkles out.
    • Be careful not to burn your fingers.
  5. How to Remove Wax From Clothing: passo 5, immagine 1 di 2 How to Remove Wax From Clothing: passo 5, immagine 2 di 2
    • Lift up the brown paper bag once it looks like the oil has saturated the bag.
    • Repeat steps 3-5 with new bags, until the remainder of the wax is soaked up.
  6. How to Remove Wax From Clothing: passo 6, immagine 1 di 1
    • Feel free to wash your item now that the wax is removed, just as you normally would.
Conclusione
To finish getting wax out it is not a bad idea to wash your item, if possible, in a washing machine for a clothing item or use carpet wash for the carpet.
Molly Green
Membro da: 04/23/20
133 Reputazione
1 Guida realizzata
0 Commenti
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 1
Ultimi 7 Giorni: 13
Ultimi 30 Giorni: 46
Tutti i Tempi: 561
