Salta al contenuto principale
How to Remove Rust on Car Body
Cosa ti serve
  1. How to Remove Rust on Car Body, How to Remove Rust on Car Body: passo 1, immagine 1 di 2 How to Remove Rust on Car Body, How to Remove Rust on Car Body: passo 1, immagine 2 di 2
    • Spray down the rust with a spray bottle mixed with water and dish soap.
    • Wipe the mixture with a microfiber cloth.
  2. How to Remove Rust on Car Body: passo 2, immagine 1 di 3 How to Remove Rust on Car Body: passo 2, immagine 2 di 3 How to Remove Rust on Car Body: passo 2, immagine 3 di 3
    • Pour a small amount of rubbing alcohol onto a microfiber cloth.
    • Clean the rusted area with the cloth to remove any contaminants.
  3. How to Remove Rust on Car Body: passo 3, immagine 1 di 3 How to Remove Rust on Car Body: passo 3, immagine 2 di 3 How to Remove Rust on Car Body: passo 3, immagine 3 di 3
    • Rub the rusted area with 80-grit sandpaper until you start seeing the bare metal.
  4. How to Remove Rust on Car Body: passo 4, immagine 1 di 2 How to Remove Rust on Car Body: passo 4, immagine 2 di 2
    • Rub the rusted area with 220-grit sandpaper until all of the rust is removed.
    • Dampen a cloth with soapy water and wipe down the sanded area.
  5. How to Remove Rust on Car Body: passo 5, immagine 1 di 2 How to Remove Rust on Car Body: passo 5, immagine 2 di 2
    • This step is to prepare your spot for spray painting.
    • Add some paper around the areas you do not want paint on. Make sure you go a little past where you are going to spray paint to blend the paint into the surrounding area.
  6. How to Remove Rust on Car Body: passo 6, immagine 1 di 3 How to Remove Rust on Car Body: passo 6, immagine 2 di 3 How to Remove Rust on Car Body: passo 6, immagine 3 di 3
    • Spray three even coats of primer, waiting at least five minutes between each coat.
    • Let the third coat sit for 15 minutes.
  7. How to Remove Rust on Car Body: passo 7, immagine 1 di 3 How to Remove Rust on Car Body: passo 7, immagine 2 di 3 How to Remove Rust on Car Body: passo 7, immagine 3 di 3
    • Spray three even coats of paint on top of the primer, waiting five minutes between each coat.
    • You can either use a color similar to your car or you can get the actual color of you car by looking for the car's color code.
    • After the final coat, wait 24 hours before removing the surrounding paper.
Linea Traguardo
0 Commenti
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 4
Ultimi 7 Giorni: 19
Ultimi 30 Giorni: 117
Tutti i Tempi: 1,802
