Salta al contenuto principale
How to Rehydrate a Dried Eyeliner Pen
Cosa ti serve
  1. How to Rehydrate a Dried Eyeliner Pen, How to Rehydrate a Dried Eyeliner Pen: passo 1, immagine 1 di 1
    • Before you start, test out your dried eyeliner pen so you can compare the results at the end!
  2. How to Rehydrate a Dried Eyeliner Pen: passo 2, immagine 1 di 2 How to Rehydrate a Dried Eyeliner Pen: passo 2, immagine 2 di 2
    Attrezzo utilizzato in questo passaggio:
    Compra
    • Remove the cap from your eyeliner pen.
    • Take a small pair of pliers and gently remove the felt rod from inside the liner.
    • Some liners may require you to unscrew the end of the liner to remove the felt rod.
    • If you do not have pliers, tweezers can also be used for this fix.
  3. How to Rehydrate a Dried Eyeliner Pen: passo 3, immagine 1 di 3 How to Rehydrate a Dried Eyeliner Pen: passo 3, immagine 2 di 3 How to Rehydrate a Dried Eyeliner Pen: passo 3, immagine 3 di 3
    • Once the felt rod has been removed, gently place the rod in a bowl of warm water for no more than 30 seconds.
    • If you notice the colour of the water starts to change, immediately remove the felt rod from the water.
  4. How to Rehydrate a Dried Eyeliner Pen: passo 4, immagine 1 di 3 How to Rehydrate a Dried Eyeliner Pen: passo 4, immagine 2 di 3 How to Rehydrate a Dried Eyeliner Pen: passo 4, immagine 3 di 3
    • Take the felt rod out of the water and immediately place it on a paper towel.
    • Gently pat the felt rod dry using a paper towel.
  5. How to Rehydrate a Dried Eyeliner Pen: passo 5, immagine 1 di 2 How to Rehydrate a Dried Eyeliner Pen: passo 5, immagine 2 di 2
    • Lastly, use a plier to fit the felt rod back into the liner pen.
  6. How to Rehydrate a Dried Eyeliner Pen: passo 6, immagine 1 di 1
    • Now test out your new eyeliner pen to see the difference!
    • The red arrow shows the before and the blue arrow shows the after.
Linea Traguardo
Nuha Naushad
Membro da: 09/11/23
133 Reputazione
1 Guida realizzata
0 Commenti
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 2
Ultimi 30 Giorni: 23
Tutti i Tempi: 130
