Salta al contenuto principale
How to Reattach the Head of a Mailbox to the Base
Cosa ti serve
  1. How to Reattach the Head of a Mailbox to the Base, How to Reattach the Head of a Mailbox to the Base: passo 1, immagine 1 di 2 How to Reattach the Head of a Mailbox to the Base, How to Reattach the Head of a Mailbox to the Base: passo 1, immagine 2 di 2
    • Inspect the head of the mailbox to see where the detachment is located.
  2. How to Reattach the Head of a Mailbox to the Base: passo 2, immagine 1 di 2 How to Reattach the Head of a Mailbox to the Base: passo 2, immagine 2 di 2
    • Gather all materials needed.
    • Adhesive can be included depending on the tight fit you desire.
  3. How to Reattach the Head of a Mailbox to the Base: passo 3, immagine 1 di 3 How to Reattach the Head of a Mailbox to the Base: passo 3, immagine 2 di 3 How to Reattach the Head of a Mailbox to the Base: passo 3, immagine 3 di 3
    • Measure out the wood plank to match the length and width of the mailbox head.
  4. How to Reattach the Head of a Mailbox to the Base: passo 4, immagine 1 di 3 How to Reattach the Head of a Mailbox to the Base: passo 4, immagine 2 di 3 How to Reattach the Head of a Mailbox to the Base: passo 4, immagine 3 di 3
    • Use a hammer or mallet to nail this wood plank to the bottom of mailbox head. Use at least four nails for this task.
    • Use gloves, if deemed necessary!
  5. How to Reattach the Head of a Mailbox to the Base: passo 5, immagine 1 di 2 How to Reattach the Head of a Mailbox to the Base: passo 5, immagine 2 di 2
    • Screw the sides down for a stronger fit using at least four screws.
  6. How to Reattach the Head of a Mailbox to the Base: passo 6, immagine 1 di 1
    • Align the mailbox head back on the post.
  7. How to Reattach the Head of a Mailbox to the Base: passo 7, immagine 1 di 2 How to Reattach the Head of a Mailbox to the Base: passo 7, immagine 2 di 2
    • Hammer down the head to the post of the mailbox with at least three more nails.
    • Add adhesive if necessary for a sturdier attachment.
    • Since your hands are inside the mailbox, it may be best to use gloves for this task.
Linea Traguardo
Terrell Cobbins
Membro da: 03/21/23
145 Reputazione
1 Guida realizzata
0 Commenti
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 2
Ultimi 7 Giorni: 8
Ultimi 30 Giorni: 25
Tutti i Tempi: 293
