Salta al contenuto principale
How to Reattach a Broken Table Leg
Cosa ti serve
  1. How to Reattach a Broken Table Leg, How to Reattach a Broken Table Leg: passo 1, immagine 1 di 1
    • Carefully place the table on an even surface and identify the broken parts.
  2. How to Reattach a Broken Table Leg: passo 2, immagine 1 di 1
    • Carefully place the table with the tabletop face down on a clean cloth or plastic cover to prevent scratching.
    • You might need some assistance depending on the size of the table.
  3. How to Reattach a Broken Table Leg: passo 3, immagine 1 di 2 How to Reattach a Broken Table Leg: passo 3, immagine 2 di 2
    • Remove the screws from the broken leg.
    • I am using a Mastercraft flathead 3 mm screwdriver in this step. Your screwdriver type will depend on the screw. Follow this guide to learn more about screwdriver types.
    • Remove the broken leg.
    • Use a paper towel to clean the surface of the table and legs.
  4. How to Reattach a Broken Table Leg: passo 4, immagine 1 di 2 How to Reattach a Broken Table Leg: passo 4, immagine 2 di 2
    • Caution: If you have sensitive skin, avoid direct contact with the glue and use gloves before performing this step.
    • Caution: Use adequate ventilation or wear a mask to prevent inhaling the glue fumes.
    • Carefully apply the glue on the part that connects the table and legs.
  5. How to Reattach a Broken Table Leg: passo 5, immagine 1 di 1
    • Press the leg against the glue for few minutes.
    • Allow the glue to dry for at least 10 minutes.
  6. How to Reattach a Broken Table Leg: passo 6, immagine 1 di 1
    • Once the glue is dry, insert the screws.
  7. How to Reattach a Broken Table Leg: passo 7, immagine 1 di 3 How to Reattach a Broken Table Leg: passo 7, immagine 2 di 3 How to Reattach a Broken Table Leg: passo 7, immagine 3 di 3
    • Use an electric drill or a screwdriver to tighten the screws.
  8. How to Reattach a Broken Table Leg: passo 8, immagine 1 di 1
    • Use a paper towel to remove extra glue stains.
    • Allow the table to dry for 24 hours before turning the table.
  9. How to Reattach a Broken Table Leg: passo 9, immagine 1 di 2 How to Reattach a Broken Table Leg: passo 9, immagine 2 di 2
    • After 24 hours, carefully return the table to the original position.
    • Depending on the size of the table, you might need some assistance to turn the table.
Conclusione
Repeat these steps to fix any other broken legs on the table.
0 Commenti
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 9
Ultimi 7 Giorni: 50
Ultimi 30 Giorni: 219
Tutti i Tempi: 9,841
