Salta al contenuto principale
How to Patch a Hole in Damaged Carpet
Cosa ti serve
  1. How to Patch a Hole in Damaged Carpet, Hole in Carpet: passo 1, immagine 1 di 3 How to Patch a Hole in Damaged Carpet, Hole in Carpet: passo 1, immagine 2 di 3 How to Patch a Hole in Damaged Carpet, Hole in Carpet: passo 1, immagine 3 di 3
    • Place a can over the hole.
    • The can should completely cover the hole.
  2. How to Patch a Hole in Damaged Carpet: passo 2, immagine 1 di 3 How to Patch a Hole in Damaged Carpet: passo 2, immagine 2 di 3 How to Patch a Hole in Damaged Carpet: passo 2, immagine 3 di 3
    • Press down firmly on the can.
    • Cut around the can with a utility knife.
    • Utility knives are sharp, so handle with care.
    • Only cut through the carpet. Do not cut through the carpet pad underneath.
  3. How to Patch a Hole in Damaged Carpet: passo 3, immagine 1 di 3 How to Patch a Hole in Damaged Carpet: passo 3, immagine 2 di 3 How to Patch a Hole in Damaged Carpet: passo 3, immagine 3 di 3
    • Remove the can.
    • Lift out the old carpet.
  4. How to Patch a Hole in Damaged Carpet: passo 4, immagine 1 di 3 How to Patch a Hole in Damaged Carpet: passo 4, immagine 2 di 3 How to Patch a Hole in Damaged Carpet: passo 4, immagine 3 di 3
    • Flip sample carpet onto its back and place down on a stable surface.
    • Place the can onto the sample carpet.
    • Trace the shape of the can with a marker.
  5. How to Patch a Hole in Damaged Carpet: passo 5, immagine 1 di 3 How to Patch a Hole in Damaged Carpet: passo 5, immagine 2 di 3 How to Patch a Hole in Damaged Carpet: passo 5, immagine 3 di 3
    • Remove the can from the sample carpet.
    • Cut out the shape from the sample carpet using scissors.
    • Kitchen scissors are sharp. Always cut away from yourself.
  6. How to Patch a Hole in Damaged Carpet: passo 6, immagine 1 di 3 How to Patch a Hole in Damaged Carpet: passo 6, immagine 2 di 3 How to Patch a Hole in Damaged Carpet: passo 6, immagine 3 di 3
    • Check to make sure the replacement piece of carpet fits into the hole.
    • If necessary, trim sample to fit or cut another piece.
  7. How to Patch a Hole in Damaged Carpet: passo 7, immagine 1 di 2 How to Patch a Hole in Damaged Carpet: passo 7, immagine 2 di 2
    • Evenly spread glue on the underside of the replacement carpet.
    • The carpet should be placed down before the glue dries.
  8. How to Patch a Hole in Damaged Carpet: passo 8, immagine 1 di 2 How to Patch a Hole in Damaged Carpet: passo 8, immagine 2 di 2
    • Place the glue side of the carpet down into the hole.
    • Press down firmly on the carpet with your hand.
    • Let glue dry before using the carpet.
  9. How to Patch a Hole in Damaged Carpet: passo 9, immagine 1 di 2 How to Patch a Hole in Damaged Carpet: passo 9, immagine 2 di 2
    • Trim carpet fibers to blend the replacement carpet with the original.
Conclusione
Once the glue has dried the carpet can be walked on or vacuumed. By cutting the longer carpet fibers the replacement patch should seamlessly blend in with the original carpet.
Altre 3 persone hanno completato questa guida.
2 Commenti
Very good. I suppose if you don't have same carpet you can match as close as possible with a new piece.
Brian Taylor - Replica
Excellent tip - thank you for sharing!!
Rama Narsing - Replica
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 18
Ultimi 7 Giorni: 131
Ultimi 30 Giorni: 583
Tutti i Tempi: 18,600
