Salta al contenuto principale
How to Install LED License Plate Lights
Cosa ti serve
  1. How to Install LED License Plate Lights, Prep work: passo 1, immagine 1 di 1
    • You can choose to raise your car with a car lift jack to get better access to the license plate area. This is not absolutely necessary, but will make installation easier.
  2. How to Install LED License Plate Lights, Removing the stock bulb: passo 2, immagine 1 di 3 How to Install LED License Plate Lights, Removing the stock bulb: passo 2, immagine 2 di 3 How to Install LED License Plate Lights, Removing the stock bulb: passo 2, immagine 3 di 3
    • Pull out the license plate lamp assembly and remove the stock license plate bulb.
  3. How to Install LED License Plate Lights, Installing the LED license plate bulb: passo 3, immagine 1 di 2 How to Install LED License Plate Lights, Installing the LED license plate bulb: passo 3, immagine 2 di 2
    • Install back the new LED license plate bulb.
    • Test to make sure the LED bulb works.
  4. How to Install LED License Plate Lights, Putting the license plate assembly back: passo 4, immagine 1 di 2 How to Install LED License Plate Lights, Putting the license plate assembly back: passo 4, immagine 2 di 2
    • Put the license plate assembly back and repeat on the other side.
  5. How to Install LED License Plate Lights, Enjoy: passo 5, immagine 1 di 1
    • Once everything works, you can enjoy your new LED license plate look.
Conclusione
See how easy installing these LED license plate lights are? It's almost unbelievable how a quick and simple installation could make such a difference.
Altre 6 persone hanno completato questa guida.
Eric Wu
Membro da: 01/21/15
3.357 Reputazione
23 Guide realizzate
2 Commenti
Why do all your pics have such obnoxious watermarks? If the pics are specifically for iFixit.com I would remove the watermarks.
David Spalding - Replica
Good information!
limoh - Replica
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 10
Ultimi 30 Giorni: 70
Tutti i Tempi: 14,910
