Salta al contenuto principale
How to Format a drive in Windows 7-10
Cosa ti serve
  1. How to Format a drive in Windows 7-10, Open File Explorer: passo 1, immagine 1 di 1
    • Open File Explorer.
    • You can do that from either of the red highlighted spots, or search for "File Explorer."
  2. How to Format a drive in Windows 7-10, Open the Format Menu: passo 2, immagine 1 di 2 How to Format a drive in Windows 7-10, Open the Format Menu: passo 2, immagine 2 di 2
    • Right-Click on the drive you want to format, and click format
    • This is what should pop up.
  3. How to Format a drive in Windows 7-10, Format your drive: passo 3, immagine 1 di 1
    • if you will be using the drive for Windows, format it as NTFS. If you need a multi-OS drive, exFAT or FAT32 is recommended. However, keep in mind FAT32 has a 4GB limit on files.
    • Use default allocation size.
    • If you want to rename your drive put the new name here.
    • Start the format. When It's done, you can close all the windows, and you are done.
Linea Traguardo
Altre 6 persone hanno completato questa guida.
George A.
Membro da: 12/07/16
21.960 Reputazione
4 Guide realizzate
Community Protectors Membro di Community Protectors
Community
19 Membri
24 Guide realizzate
0 Commenti
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 3
Ultimi 7 Giorni: 33
Ultimi 30 Giorni: 94
Tutti i Tempi: 1,120
