Salta al contenuto principale
How to Fix an Umbrella Rivet
Cosa ti serve
  1. How to Fix an Umbrella Rivet, How to Fix an Umbrella Rivet: passo 1, immagine 1 di 1
    • Open the umbrella into its proper position.
  2. How to Fix an Umbrella Rivet: passo 2, immagine 1 di 1
    • Identify the broken stretcher that needs to be repaired.
  3. How to Fix an Umbrella Rivet: passo 3, immagine 1 di 1
    • Close the umbrella halfway to release the tension in the stretchers.
    • This makes it easier to line up the holes in the next step.
  4. How to Fix an Umbrella Rivet: passo 4, immagine 1 di 1
    • Take the two pieces of the broken stretcher and line up the rivet holes.
  5. How to Fix an Umbrella Rivet: passo 5, immagine 1 di 1
    • Pass the 6" piece of wire through the rivet holes.
  6. How to Fix an Umbrella Rivet: passo 6, immagine 1 di 1
    • Wrap the wire around the stretcher and thread it through the holes again.
    • Repeat until there is no more room to pass the wire through.
    • May need to use the pliers to get a better grip on the wire so it can be pulled tight.
  7. How to Fix an Umbrella Rivet: passo 7, immagine 1 di 1
    • Tie two half-hitch knots with the wire.
    • If you do not know how to tie a half-hitch knot, follow the link provided at the beginning of the guide.
  8. How to Fix an Umbrella Rivet: passo 8, immagine 1 di 1
    • Use the scissors to trim the two ends of the wire to about half an inch in length.
  9. How to Fix an Umbrella Rivet: passo 9, immagine 1 di 1
    • Using the pliers, twist the ends of the wire together.
  10. How to Fix an Umbrella Rivet: passo 10, immagine 1 di 1
    • Tuck the wires down and clamp with the pliers so the ends are not poking out.
Linea Traguardo
Altre 6 persone hanno completato questa guida.
Texas Tech, Team 3-8, Rauch SU 2016 Membro di Texas Tech, Team 3-8, Rauch SU 2016
TTU-RAUCH-SU16S3G8
2 Membri
3 Guide realizzate
7 Commenti
This is not called an ‘umbrella rivet replacement’.
SouthPark - Replica
I fixed my umbrella! Thank you. Umbrella is very old though, will see how much more time I can buy with this fix :)
Lou - Replica
The fix lasted about a month and a half and then the copper wire broke. I am trying the same technique but this time with a metal paper clip that I had. The paper clip is made of metal that's thicker than the copper wire. I only threaded it through one time and then twisted the ends. One paper clip was enough to fix 2 rivets (both the original one and a new one is now broken as well). I will try to report back if these also break.
Lou - Replica
6 months later and paperclip fix is still holding!
Lou -
Thanks! A paperclip worked!
Mayra L. -
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 24
Ultimi 7 Giorni: 231
Ultimi 30 Giorni: 670
Tutti i Tempi: 21,118
