Salta al contenuto principale
How to Fix a Wobbly Leg on a Solid Wood Chair
Cosa ti serve
  1. How to Fix a Wobbly Leg on a Solid Wood Chair, How to Fix a Wobbly Leg on a Solid Wood Chair: passo 1, immagine 1 di 1
    • First, thoroughly assess your chair for loose elements.
    • Sit and jiggle them to test and note exactly what moves.
  2. How to Fix a Wobbly Leg on a Solid Wood Chair: passo 2, immagine 1 di 3 How to Fix a Wobbly Leg on a Solid Wood Chair: passo 2, immagine 2 di 3 How to Fix a Wobbly Leg on a Solid Wood Chair: passo 2, immagine 3 di 3
    • Position an L-bracket as if it will brace the leg to the frame of the chair.
    • Mark the exact outline of the bracket, taking extra care when marking the center hole where your screws will hold the brace in place.
    • It might be beneficial to "x" the through the marked circles to approximate the exact center for the screw to enter.
  3. How to Fix a Wobbly Leg on a Solid Wood Chair: passo 3, immagine 1 di 2 How to Fix a Wobbly Leg on a Solid Wood Chair: passo 3, immagine 2 di 2
    • If possible, detach your chair legs.
    • In the case you cannot detach your chair legs, consider buying longer L-brackets so you still have enough room to hold your drill parallel to the chair surfaces.
  4. How to Fix a Wobbly Leg on a Solid Wood Chair: passo 4, immagine 1 di 1
    • Check if the drill bit is longer than the width of the chair leg.
    • If so, consider marking the drill bit to your desired depth.
  5. How to Fix a Wobbly Leg on a Solid Wood Chair: passo 5, immagine 1 di 3 How to Fix a Wobbly Leg on a Solid Wood Chair: passo 5, immagine 2 di 3 How to Fix a Wobbly Leg on a Solid Wood Chair: passo 5, immagine 3 di 3
    • Before drilling any holes, ensure that your drill bit is slightly smaller than the width of your screw. This will result in a more secure hold.
    • Pre-drill holes through the center of your marked circles on both your chair legs and chair frame.
  6. How to Fix a Wobbly Leg on a Solid Wood Chair: passo 6, immagine 1 di 2 How to Fix a Wobbly Leg on a Solid Wood Chair: passo 6, immagine 2 di 2
    • Using the drill, secure your L-brackets to the chair legs first.
    • Be sure to hold the drill and screw parallel to the drilling surface.
  7. How to Fix a Wobbly Leg on a Solid Wood Chair: passo 7, immagine 1 di 1
    • For extra hold and durability, use a small amount of wood glue at the chair legs joints.
    • Be sure to wipe away any excess wood glue.
  8. How to Fix a Wobbly Leg on a Solid Wood Chair: passo 8, immagine 1 di 2 How to Fix a Wobbly Leg on a Solid Wood Chair: passo 8, immagine 2 di 2
    • Tighten any preexisting hardware holding the legs to the chair base before fixing the L-bracket to the chair.
  9. How to Fix a Wobbly Leg on a Solid Wood Chair: passo 9, immagine 1 di 2 How to Fix a Wobbly Leg on a Solid Wood Chair: passo 9, immagine 2 di 2
    • Finally, screw the second side of the L-bracket to the base of the chair.
Conclusione
Reassemble any remaining loose pieces as they were disassembled unless otherwise noted.
Altre 2 persone hanno completato questa guida.
UC Davis, Team S2-G6, Cole Spring 2017 Membro di UC Davis, Team S2-G6, Cole Spring 2017
UCD-COLE-S17S2G6
3 Membri
1 Guida realizzata
Un commento
My entire corner wood pieces are broken and not fixable and the screen (bolt and nut) is bended also. I would like to purchase those small wood pieces, I am not a saavy. Need some help to find the pieces. you can mail me @ radhu_murali@hotmail.com.
Radhika Murali - Replica
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 20
Ultimi 7 Giorni: 85
Ultimi 30 Giorni: 330
Tutti i Tempi: 30,845
