Salta al contenuto principale
How to Fix a Stuck Quarter in a Candy Machine
Cosa ti serve
  1. How to Fix a Stuck Quarter in a  Candy Machine, How to Fix a Stuck Quarter in a  Candy Machine: passo 1, immagine 1 di 3 How to Fix a Stuck Quarter in a  Candy Machine, How to Fix a Stuck Quarter in a  Candy Machine: passo 1, immagine 2 di 3 How to Fix a Stuck Quarter in a  Candy Machine, How to Fix a Stuck Quarter in a  Candy Machine: passo 1, immagine 3 di 3
    • Remove the lid of the machine.
    • Remove candy from container and place aside in a bowl.
  2. How to Fix a Stuck Quarter in a  Candy Machine: passo 2, immagine 1 di 3 How to Fix a Stuck Quarter in a  Candy Machine: passo 2, immagine 2 di 3 How to Fix a Stuck Quarter in a  Candy Machine: passo 2, immagine 3 di 3
    • Using a flathead screwdriver unscrew the four 10mm corner screws.
    • Remove the plastic container and set it aside.
  3. How to Fix a Stuck Quarter in a  Candy Machine: passo 3, immagine 1 di 2 How to Fix a Stuck Quarter in a  Candy Machine: passo 3, immagine 2 di 2
    • Using a Phillips #1 screwdriver remove the two 15mm screws that are marked in the photo.
  4. How to Fix a Stuck Quarter in a  Candy Machine: passo 4, immagine 1 di 2 How to Fix a Stuck Quarter in a  Candy Machine: passo 4, immagine 2 di 2
    • Remove the inner mechanisms by sliding them up and off the metal rod.
  5. How to Fix a Stuck Quarter in a  Candy Machine: passo 5, immagine 1 di 2 How to Fix a Stuck Quarter in a  Candy Machine: passo 5, immagine 2 di 2
    • Remove the metal top with both hands on the sides.
    • Lift up, sliding it up and off the metal rod.
  6. How to Fix a Stuck Quarter in a  Candy Machine: passo 6, immagine 1 di 3 How to Fix a Stuck Quarter in a  Candy Machine: passo 6, immagine 2 di 3 How to Fix a Stuck Quarter in a  Candy Machine: passo 6, immagine 3 di 3
    • Now you can see into the inner mechanisms.
    • Locate the stuck quarter and try to remove it.
    • For better access, lift up the left hinge to release the entire mechanism.
  7. How to Fix a Stuck Quarter in a  Candy Machine: passo 7, immagine 1 di 2 How to Fix a Stuck Quarter in a  Candy Machine: passo 7, immagine 2 di 2
    • Remove the inner mechanism by pulling out one side before sliding out the whole mechanism.
  8. How to Fix a Stuck Quarter in a  Candy Machine: passo 8, immagine 1 di 2 How to Fix a Stuck Quarter in a  Candy Machine: passo 8, immagine 2 di 2
    • Find the stuck quarter in the mechanism.
    • Remove the quarter with your hands by simply pulling (use a plier if needed).
  9. How to Fix a Stuck Quarter in a  Candy Machine: passo 9, immagine 1 di 2 How to Fix a Stuck Quarter in a  Candy Machine: passo 9, immagine 2 di 2
    • Slide the mechanism back in, right side in first followed by left.
    • Lock the mechanism in place by sliding the hinge lock back down.
  10. How to Fix a Stuck Quarter in a  Candy Machine: passo 10, immagine 1 di 2 How to Fix a Stuck Quarter in a  Candy Machine: passo 10, immagine 2 di 2
    • Return the metal top by sliding it back down the metal rod.
    • To secure the metal top back into place pull it forward so it covers the front of the machine.
  11. How to Fix a Stuck Quarter in a  Candy Machine: passo 11, immagine 1 di 3 How to Fix a Stuck Quarter in a  Candy Machine: passo 11, immagine 2 di 3 How to Fix a Stuck Quarter in a  Candy Machine: passo 11, immagine 3 di 3
    • Slide the rotation mechanism back down so it sits with one of the three holes is fully over the hole.
    • Slide down the cover mechanism so it aligns with the screw holes.
    • Use a phillips head screwdriver to screw down the two side screws.
  12. How to Fix a Stuck Quarter in a  Candy Machine: passo 12, immagine 1 di 2 How to Fix a Stuck Quarter in a  Candy Machine: passo 12, immagine 2 di 2
    • Replace the plastic container so it aligns with the four screw holes.
    • Replace the four screws using a flat head screwdriver.
  13. How to Fix a Stuck Quarter in a  Candy Machine: passo 13, immagine 1 di 2 How to Fix a Stuck Quarter in a  Candy Machine: passo 13, immagine 2 di 2
    • Replace the candy and the lid.
    • Enjoy your sweet tooth adventures.
Conclusione
I hope this guide helps you understand how to fix and change your candy machine, enjoy your candy!
0 Commenti
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 1
Ultimi 7 Giorni: 6
Ultimi 30 Giorni: 36
Tutti i Tempi: 1,856
