Salta al contenuto principale
How to Fix a Misaligned Desk Drawer
Cosa ti serve
  1. How to Fix a Misaligned Desk Drawer, How to Fix a Misaligned Desk Drawer: passo 1, immagine 1 di 2 How to Fix a Misaligned Desk Drawer, How to Fix a Misaligned Desk Drawer: passo 1, immagine 2 di 2
    • Start by pulling the drawer out and detaching it from the hardware mounted to the desk.
    • To do this you need to push the black plastic lever up in order to disengage the drawer's hardware from the desk's hardware.
  2. How to Fix a Misaligned Desk Drawer: passo 2, immagine 1 di 2 How to Fix a Misaligned Desk Drawer: passo 2, immagine 2 di 2
    • In this case the hardware on the left side of the drawer is not functioning properly due to a bent metal piece.
    • Using the flat head screwdriver you can push the metal down around each ball bearing in order to allow the drawer to slide back and forth.
  3. How to Fix a Misaligned Desk Drawer: passo 3, immagine 1 di 2 How to Fix a Misaligned Desk Drawer: passo 3, immagine 2 di 2
    • The hardware attached to the drawer is also not functioning properly due to missing screws.
    • Use replacement screws to properly attach the hardware to the drawer and to allow it to support the drawer's weight.
    • Take a screw from the drawer to your local hardware store for help finding matching screws.
  4. How to Fix a Misaligned Desk Drawer: passo 4, immagine 1 di 1
    • After attaching the hardware slide the drawer's piece into its counterpart on the desk.
    • It can be awkward to maneuver the drawer in alone. You may need to get some help for this step.
  5. How to Fix a Misaligned Desk Drawer: passo 5, immagine 1 di 1
    • Enjoy your fully functioning drawer!
Conclusione
0 Commenti
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 1
Ultimi 7 Giorni: 6
Ultimi 30 Giorni: 39
Tutti i Tempi: 16,022
