Salta al contenuto principale
How to Fix a Loose Turret on a Sony Cyber-shot DSC-F828
Cosa ti serve
  1. How to Fix a Loose Turret on a Sony Cyber-shot DSC-F828, How to Fix a Loose Turret on a Sony Cyber-shot DSC-F828: passo 1, immagine 1 di 2 How to Fix a Loose Turret on a Sony Cyber-shot DSC-F828, How to Fix a Loose Turret on a Sony Cyber-shot DSC-F828: passo 1, immagine 2 di 2
    • Slide the button back to open the battery cover.
  2. How to Fix a Loose Turret on a Sony Cyber-shot DSC-F828: passo 2, immagine 1 di 2 How to Fix a Loose Turret on a Sony Cyber-shot DSC-F828: passo 2, immagine 2 di 2
    • Pull back on the tab to release the battery.
    • Pull the battery out, then close the lid.
  3. How to Fix a Loose Turret on a Sony Cyber-shot DSC-F828: passo 3, immagine 1 di 1
    • Remove the screw on the back of the turret with a JIS #00 screwdriver.
  4. How to Fix a Loose Turret on a Sony Cyber-shot DSC-F828: passo 4, immagine 1 di 2 How to Fix a Loose Turret on a Sony Cyber-shot DSC-F828: passo 4, immagine 2 di 2
    • Remove two screws from each side of the camera (four in total) using a JIS #00 screwdriver.
  5. How to Fix a Loose Turret on a Sony Cyber-shot DSC-F828: passo 5, immagine 1 di 1
    • Remove the screw on the bottom of the turret using a JIS #00 screwdriver.
  6. How to Fix a Loose Turret on a Sony Cyber-shot DSC-F828: passo 6, immagine 1 di 1
    • Carefully pull the face plate off and lay it down.
    • There is a cable attached to the plate that should not be removed.
  7. How to Fix a Loose Turret on a Sony Cyber-shot DSC-F828: passo 7, immagine 1 di 2 How to Fix a Loose Turret on a Sony Cyber-shot DSC-F828: passo 7, immagine 2 di 2
    • Tighten the two screws using a JIS #00 screwdriver.
Conclusione
Altre 5 persone hanno completato questa guida.
Un commento
Thanks, I just used this to tighten the pivot on an F828 I got on eBay. Super easy.
photoman12001 - Replica
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 2
Ultimi 7 Giorni: 9
Ultimi 30 Giorni: 38
Tutti i Tempi: 1,125
