Salta al contenuto principale
How to Fix a Loose Cookware Lid Handle
  1. How to Fix a Loose Cookware Lid Handle, How to Fix a Loose Cookware Lid Handle: passo 1, immagine 1 di 1
    • Wash the glass of the lid with hot water.
    • Be sure to scrub underneath and around the handle.
  2. How to Fix a Loose Cookware Lid Handle: passo 2, immagine 1 di 1
    • Clean the glass lid with a dry piece of cloth.
    • Make sure to especially clean below and around the handle.
  3. How to Fix a Loose Cookware Lid Handle: passo 3, immagine 1 di 2 How to Fix a Loose Cookware Lid Handle: passo 3, immagine 2 di 2
    • Unscrew the handle from the lid and remove the screw and washer.
  4. How to Fix a Loose Cookware Lid Handle: passo 4, immagine 1 di 2 How to Fix a Loose Cookware Lid Handle: passo 4, immagine 2 di 2
    • Clean the hole of the handle with a drop of vinegar and baking soda.
    • Firmly apply the drop of vinegar and baking soda below and underneath the hole, which will clear the surface of any dirt.
  5. How to Fix a Loose Cookware Lid Handle: passo 5, immagine 1 di 3 How to Fix a Loose Cookware Lid Handle: passo 5, immagine 2 di 3 How to Fix a Loose Cookware Lid Handle: passo 5, immagine 3 di 3
    • Clean the screw and washer with a drop of vinegar and baking soda.
    • Allow the parts to dry for about 1-2 minutes.
  6. How to Fix a Loose Cookware Lid Handle: passo 6, immagine 1 di 2 How to Fix a Loose Cookware Lid Handle: passo 6, immagine 2 di 2
    • Apply super glue around the hole of the handle.
    • Be cautious when using super glue that you don't spill it over the bigger glass surface.
  7. How to Fix a Loose Cookware Lid Handle: passo 7, immagine 1 di 3 How to Fix a Loose Cookware Lid Handle: passo 7, immagine 2 di 3 How to Fix a Loose Cookware Lid Handle: passo 7, immagine 3 di 3
    • Quickly install the handle back onto the lid using the screw and washer.
    • Be careful not to touch the glue with your fingers.
    • Once again keep it dry for about 4-5 minutes.
    • The loose handle on your glass lid is fixed and ready to use.
Conclusione
Dinuk Warnapura
Membro da: 01/11/21
145 Reputazione
1 Guida realizzata
0 Commenti
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 6
Ultimi 7 Giorni: 19
Ultimi 30 Giorni: 74
Tutti i Tempi: 1,992
