Salta al contenuto principale
How to Fix a Loose Connector in an Anivia 1080p Webcam
Cosa ti serve
  1. How to Fix a Loose Connector in an Anivia 1080p Webcam, How to Fix a Loose Connector in an Anivia 1080p Webcam: passo 1, immagine 1 di 3 How to Fix a Loose Connector in an Anivia 1080p Webcam, How to Fix a Loose Connector in an Anivia 1080p Webcam: passo 1, immagine 2 di 3 How to Fix a Loose Connector in an Anivia 1080p Webcam, How to Fix a Loose Connector in an Anivia 1080p Webcam: passo 1, immagine 3 di 3
    • Pry open the face plate of the webcam using the iFixit opening pick or another safe tool, and set it aside.
  2. How to Fix a Loose Connector in an Anivia 1080p Webcam: passo 2, immagine 1 di 3 How to Fix a Loose Connector in an Anivia 1080p Webcam: passo 2, immagine 2 di 3 How to Fix a Loose Connector in an Anivia 1080p Webcam: passo 2, immagine 3 di 3
    • Remove the three main screws using a Phillips screwdriver while carefully holding the camera motherboard in place.
  3. How to Fix a Loose Connector in an Anivia 1080p Webcam: passo 3, immagine 1 di 3 How to Fix a Loose Connector in an Anivia 1080p Webcam: passo 3, immagine 2 di 3 How to Fix a Loose Connector in an Anivia 1080p Webcam: passo 3, immagine 3 di 3
    • Remove the camera and motherboard from the casing carefully.
  4. How to Fix a Loose Connector in an Anivia 1080p Webcam: passo 4, immagine 1 di 3 How to Fix a Loose Connector in an Anivia 1080p Webcam: passo 4, immagine 2 di 3 How to Fix a Loose Connector in an Anivia 1080p Webcam: passo 4, immagine 3 di 3
    • Detach the cable from the connecter on the motherboard.
    • Pull from the plastic as to not damage any of the wires.
  5. How to Fix a Loose Connector in an Anivia 1080p Webcam: passo 5, immagine 1 di 3 How to Fix a Loose Connector in an Anivia 1080p Webcam: passo 5, immagine 2 di 3 How to Fix a Loose Connector in an Anivia 1080p Webcam: passo 5, immagine 3 di 3
    • Identify where the connector is loose and solder the piece back into place.
    • Use only as little solder as needed to keep functionality in tact.
    • Caution: The soldering iron is hot and should be handled with care.
  6. How to Fix a Loose Connector in an Anivia 1080p Webcam: passo 6, immagine 1 di 2 How to Fix a Loose Connector in an Anivia 1080p Webcam: passo 6, immagine 2 di 2
    • Reattach the cable to the connector.
  7. How to Fix a Loose Connector in an Anivia 1080p Webcam: passo 7, immagine 1 di 2 How to Fix a Loose Connector in an Anivia 1080p Webcam: passo 7, immagine 2 di 2
    • Place the motherboard and camera back into the casing.
  8. How to Fix a Loose Connector in an Anivia 1080p Webcam: passo 8, immagine 1 di 3 How to Fix a Loose Connector in an Anivia 1080p Webcam: passo 8, immagine 2 di 3 How to Fix a Loose Connector in an Anivia 1080p Webcam: passo 8, immagine 3 di 3
    • Screw the camera and motherboard back into place.
  9. How to Fix a Loose Connector in an Anivia 1080p Webcam: passo 9, immagine 1 di 3 How to Fix a Loose Connector in an Anivia 1080p Webcam: passo 9, immagine 2 di 3 How to Fix a Loose Connector in an Anivia 1080p Webcam: passo 9, immagine 3 di 3
    • Snap the faceplate covering back into place.
Linea Traguardo
0 Commenti
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 4
Ultimi 7 Giorni: 10
Ultimi 30 Giorni: 48
Tutti i Tempi: 895
