Salta al contenuto principale
How to Fix a Crooked Cabinet
Cosa ti serve
  1. How to Fix a Crooked Cabinet, Examine the Issue: passo 1, immagine 1 di 3 How to Fix a Crooked Cabinet, Examine the Issue: passo 1, immagine 2 di 3 How to Fix a Crooked Cabinet, Examine the Issue: passo 1, immagine 3 di 3
    • Examine which door needs to be adjusted and to what extent.
  2. How to Fix a Crooked Cabinet, Unscrew the Bottom Screws: passo 2, immagine 1 di 3 How to Fix a Crooked Cabinet, Unscrew the Bottom Screws: passo 2, immagine 2 di 3 How to Fix a Crooked Cabinet, Unscrew the Bottom Screws: passo 2, immagine 3 di 3
    • Hold onto the cabinet as you unscrew the two bottom screws to reposition it.
    • Tighten the screws to adjust accordingly.
  3. How to Fix a Crooked Cabinet, Repeat with the Top Screws: passo 3, immagine 1 di 3 How to Fix a Crooked Cabinet, Repeat with the Top Screws: passo 3, immagine 2 di 3 How to Fix a Crooked Cabinet, Repeat with the Top Screws: passo 3, immagine 3 di 3
    • Repeat Step 2 with the screws at the top.
  4. How to Fix a Crooked Cabinet, Adjust to Gap: passo 4, immagine 1 di 1
    • The gap should be even from top to bottom, ensure that it is and hold the cabinet in place to adjust if it is not.
  5. How to Fix a Crooked Cabinet, Feel Accomplished: passo 5, immagine 1 di 2 How to Fix a Crooked Cabinet, Feel Accomplished: passo 5, immagine 2 di 2
    • You've done it! As long as the gap is even, your results should be just like this.
    • Great job!
Linea Traguardo
Elmore Smith
Membro da: 11/20/22
148 Reputazione
1 Guida realizzata
0 Commenti
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 4
Ultimi 7 Giorni: 15
Ultimi 30 Giorni: 85
Tutti i Tempi: 963
