Salta al contenuto principale
How to Fix a Chair Armrest
Cosa ti serve
  1. How to Fix a Chair Armrest, How to Fix a Chair Armrest: passo 1, immagine 1 di 3 How to Fix a Chair Armrest, How to Fix a Chair Armrest: passo 1, immagine 2 di 3 How to Fix a Chair Armrest, How to Fix a Chair Armrest: passo 1, immagine 3 di 3
    • Remove the armrest from the chair using a hex wrench screwdriver and a drill to remove the screws.
    • You can also use a screwdriver instead of a drill.
  2. How to Fix a Chair Armrest: passo 2, immagine 1 di 2 How to Fix a Chair Armrest: passo 2, immagine 2 di 2
    • This is the chair that we will fix, and the armrest that was broken.
  3. How to Fix a Chair Armrest: passo 3, immagine 1 di 2 How to Fix a Chair Armrest: passo 3, immagine 2 di 2
    • Sand just the inside tip of the armrest as shown.
  4. How to Fix a Chair Armrest: passo 4, immagine 1 di 2 How to Fix a Chair Armrest: passo 4, immagine 2 di 2
    • Apply a little bit of glue on the part that you sanded.
    • It is fine if you do not want to use glue.
  5. How to Fix a Chair Armrest: passo 5, immagine 1 di 2 How to Fix a Chair Armrest: passo 5, immagine 2 di 2
    • Put the screw washer on the screw.
  6. How to Fix a Chair Armrest: passo 6, immagine 1 di 3 How to Fix a Chair Armrest: passo 6, immagine 2 di 3 How to Fix a Chair Armrest: passo 6, immagine 3 di 3
    • Insert the screw inside the hole on the inside of the chair body.
    • Have another person attach the armrest and then screw it with your hand.
  7. How to Fix a Chair Armrest: passo 7, immagine 1 di 2 How to Fix a Chair Armrest: passo 7, immagine 2 di 2
    • Insert the screw into the end of the armrest, attaching it to the edge of the back of the chair using a drill.
    • You may also use a screwdriver instead of a drill.
  8. How to Fix a Chair Armrest: passo 8, immagine 1 di 3 How to Fix a Chair Armrest: passo 8, immagine 2 di 3 How to Fix a Chair Armrest: passo 8, immagine 3 di 3
    • Tighten up the screw with a hex wrench screwdriver.
  9. How to Fix a Chair Armrest: passo 9, immagine 1 di 2 How to Fix a Chair Armrest: passo 9, immagine 2 di 2
    • All done! Now your armrest should feel securely attached to the chair.
Conclusione
These are moderate step to fix your chair armrest.
Deviny
Membro da: 03/23/21
196 Reputazione
1 Guida realizzata
0 Commenti
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 2
Ultimi 7 Giorni: 13
Ultimi 30 Giorni: 55
Tutti i Tempi: 2,509
