Salta al contenuto principale
How to Fix a Broken Strap on a Strapback Hat
Cosa ti serve
  1. How to Fix a Broken Strap on a Strapback Hat, How to Fix a Broken Strap on a Strapback Hat: passo 1, immagine 1 di 3 How to Fix a Broken Strap on a Strapback Hat, How to Fix a Broken Strap on a Strapback Hat: passo 1, immagine 2 di 3 How to Fix a Broken Strap on a Strapback Hat, How to Fix a Broken Strap on a Strapback Hat: passo 1, immagine 3 di 3
    • Measure the thread.
    • We recommend an arms-length amount of thread to ensure its enough to complete the fix without needing more thread.
    • Cut the thread at desired length.
  2. How to Fix a Broken Strap on a Strapback Hat: passo 2, immagine 1 di 2 How to Fix a Broken Strap on a Strapback Hat: passo 2, immagine 2 di 2
    • Thread the needle.
  3. How to Fix a Broken Strap on a Strapback Hat: passo 3, immagine 1 di 2 How to Fix a Broken Strap on a Strapback Hat: passo 3, immagine 2 di 2
    • Pull the thread through the needle until both ends of the thread meet.
    • Tie a knot at the end of the thread.
  4. How to Fix a Broken Strap on a Strapback Hat: passo 4, immagine 1 di 2 How to Fix a Broken Strap on a Strapback Hat: passo 4, immagine 2 di 2
    • Position the strap to where it was originally located on the hat.
  5. How to Fix a Broken Strap on a Strapback Hat: passo 5, immagine 1 di 2 How to Fix a Broken Strap on a Strapback Hat: passo 5, immagine 2 di 2
    • Ensure that the strap doesn't move by using a binder clip to hold it in place.
  6. How to Fix a Broken Strap on a Strapback Hat: passo 6, immagine 1 di 3 How to Fix a Broken Strap on a Strapback Hat: passo 6, immagine 2 di 3 How to Fix a Broken Strap on a Strapback Hat: passo 6, immagine 3 di 3
    • Starting on the inside of the hat, poke the needle through the cap and loose strap.
    • Pull the needle through the fabric and out the other end.
  7. How to Fix a Broken Strap on a Strapback Hat: passo 7, immagine 1 di 2 How to Fix a Broken Strap on a Strapback Hat: passo 7, immagine 2 di 2
    • Move the needle a few millimeters to the left and poke the needle through the front of the hat.
    • Pull the needle out on the other end.
  8. How to Fix a Broken Strap on a Strapback Hat: passo 8, immagine 1 di 2 How to Fix a Broken Strap on a Strapback Hat: passo 8, immagine 2 di 2
    • Repeat steps 6 and 7 until the strap is fully sewn onto the hat.
  9. How to Fix a Broken Strap on a Strapback Hat: passo 9, immagine 1 di 3 How to Fix a Broken Strap on a Strapback Hat: passo 9, immagine 2 di 3 How to Fix a Broken Strap on a Strapback Hat: passo 9, immagine 3 di 3
    • Tie a knot as close to the base of the hat as possible and cut the thread.
  10. How to Fix a Broken Strap on a Strapback Hat: passo 10, immagine 1 di 1
    • Your hat is fixed and ready to wear!
Conclusione
Congratulations! With some simple hand sewing, you were able to fix the broken strap on your hat.
Sarah Sy
Membro da: 02/02/23
181 Reputazione
1 Guida realizzata
UC Davis, Team 1-1, Andersen Winter 2023 Membro di UC Davis, Team 1-1, Andersen Winter 2023
UCD-ANDERSEN-W23S1G1
3 Membri
1 Guida realizzata
0 Commenti
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 16
Ultimi 7 Giorni: 87
Ultimi 30 Giorni: 382
Tutti i Tempi: 3,417
