Salta al contenuto principale
How to Fix a Broken Ceramic Vase
Cosa ti serve
  1. How to Fix a Broken Ceramic Vase, How to Fix a Broken Ceramic Vase: passo 1, immagine 1 di 1
    • Examine the damage to the vase. Determine how large the cracks and chips are.
    • Smaller cracks can be fixed with a ceramic adhesive, while larger cracks may require putty.
  2. How to Fix a Broken Ceramic Vase: passo 2, immagine 1 di 1
    • Sand the broken edges and cracked pieces on the vase with a sander block.
  3. How to Fix a Broken Ceramic Vase: passo 3, immagine 1 di 2 How to Fix a Broken Ceramic Vase: passo 3, immagine 2 di 2
    • Apply ceramic adhesive to the broken pieces and press them together for two minutes.
  4. How to Fix a Broken Ceramic Vase: passo 4, immagine 1 di 1
    • Secure masking tape over the cracks and let the vase dry for 3 hours.
  5. How to Fix a Broken Ceramic Vase: passo 5, immagine 1 di 1
    • After the vase dries, clean the areas with a cloth where chunks of ceramic are missing.
  6. How to Fix a Broken Ceramic Vase: passo 6, immagine 1 di 2 How to Fix a Broken Ceramic Vase: passo 6, immagine 2 di 2
    • Use a chisel scraper to fill in the missing areas with putty and allow it to dry completely.
  7. How to Fix a Broken Ceramic Vase: passo 7, immagine 1 di 1
    • Select a paint that matches the vase and use a soft paintbrush to paint the dry putty wall.
  8. How to Fix a Broken Ceramic Vase: passo 8, immagine 1 di 1
    • Let the paint dry for one hour on the vase and your repair is finished.
Linea Traguardo
0 Commenti
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 1
Ultimi 7 Giorni: 30
Ultimi 30 Giorni: 142
Tutti i Tempi: 1,276
