Salta al contenuto principale
How to Fix Ray-Ban Clubmaster Eyeglasses
Cosa ti serve
  1. How to Fix Ray-Ban Clubmaster Eyeglasses, How to Fix Ray-Ban Clubmaster Eyeglasses: passo 1, immagine 1 di 1
    • Using the toothpick, remove any manufacturing adhesive inside the top bar of the frame.
  2. How to Fix Ray-Ban Clubmaster Eyeglasses: passo 2, immagine 1 di 1
    • Apply rubbing alcohol to a cotton ball and clean inside the top bar of the Clubmaster frame.
  3. How to Fix Ray-Ban Clubmaster Eyeglasses: passo 3, immagine 1 di 2 How to Fix Ray-Ban Clubmaster Eyeglasses: passo 3, immagine 2 di 2
    • Let the alcohol dry and apply a thin layer of super glue along the inside of the top bar of the frame, from edge to edge.
    • The glue should not be overflowing out of the top bar.
    • Wear disposable gloves to avoid contact with skin.
  4. How to Fix Ray-Ban Clubmaster Eyeglasses: passo 4, immagine 1 di 1
    • Firmly press the glasses lens(es) inside the frame.
  5. How to Fix Ray-Ban Clubmaster Eyeglasses: passo 5, immagine 1 di 1
    • Wipe away any excess glue on the lens(es) and frame with a piece of paper towel.
    • Avoid smudging the glue on the glasses.
  6. How to Fix Ray-Ban Clubmaster Eyeglasses: passo 6, immagine 1 di 2 How to Fix Ray-Ban Clubmaster Eyeglasses: passo 6, immagine 2 di 2
    • Place the glasses upside down on a piece of paper towel and set in a cool place to dry for 24 hours.
Conclusione
If the guide is followed properly your Clubmaster eyeglasses should hold up perfectly!
Altre 4 persone hanno completato questa guida.
0 Commenti
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 2
Ultimi 7 Giorni: 12
Ultimi 30 Giorni: 79
Tutti i Tempi: 3,348
