Salta al contenuto principale
How to Fix Broken Pottery Using Kintsugi
Cosa ti serve
  1. How to Fix Broken Pottery Using Kintsugi, How to Fix Broken Pottery Using Kintsugi: passo 1, immagine 1 di 1
    • Clean the pottery with water and dry it with a towel.
  2. How to Fix Broken Pottery Using Kintsugi: passo 2, immagine 1 di 1
    • Combine the resin and the hardener in a container creating the epoxy.
    • Add 3 drops of each (resin and hardener).
  3. How to Fix Broken Pottery Using Kintsugi: passo 3, immagine 1 di 1
    • Use a craft stick to add the gold powder (Mica Powder) into the combination of resin and hardener.
    • Use a pinch of the Mica Powder.
  4. How to Fix Broken Pottery Using Kintsugi: passo 4, immagine 1 di 1
    • Stir the combination (epoxy and Mica Powder) with a tooth pick.
    • Make sure to not leave the combination (epoxy and Mica Powder) too long without stirring because it will begin to harden.
  5. How to Fix Broken Pottery Using Kintsugi: passo 5, immagine 1 di 1
    • Apply the combination (epoxy and Mica Powder) on one piece of the pottery.
    • Make sure one of the broken pieces is fully covered with the combination before placing the pieces together.
  6. How to Fix Broken Pottery Using Kintsugi: passo 6, immagine 1 di 1
    • Combine both pieces of pottery and allow the epoxy to dry for 5 minutes.
Linea Traguardo
Hannah Rickman
Membro da: 03/22/23
133 Reputazione
1 Guida realizzata
0 Commenti
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 1
Ultimi 30 Giorni: 18
Tutti i Tempi: 189
