Salta al contenuto principale
How to Fix Broken Porch Entry Stairs
Cosa ti serve
  1. How to Fix Broken Porch Entry Stairs, Stair treads and risers: passo 1, immagine 1 di 3 How to Fix Broken Porch Entry Stairs, Stair treads and risers: passo 1, immagine 2 di 3 How to Fix Broken Porch Entry Stairs, Stair treads and risers: passo 1, immagine 3 di 3
    • Use a pry bar to remove the pre-existing damaged wood pieces.
    • Start with the riser first.
    • Be mindful of possible rusted screws/nails.
  2. How to Fix Broken Porch Entry Stairs: passo 2, immagine 1 di 3 How to Fix Broken Porch Entry Stairs: passo 2, immagine 2 di 3 How to Fix Broken Porch Entry Stairs: passo 2, immagine 3 di 3
    • Remove the treads on the stairs.
  3. How to Fix Broken Porch Entry Stairs: passo 3, immagine 1 di 2 How to Fix Broken Porch Entry Stairs: passo 3, immagine 2 di 2
    • Use a measuring tape to measure the foundation where the new steps will be placed.
    • To ensure accurate measurements, make sure to repeat this step twice.
  4. How to Fix Broken Porch Entry Stairs: passo 4, immagine 1 di 3 How to Fix Broken Porch Entry Stairs: passo 4, immagine 2 di 3 How to Fix Broken Porch Entry Stairs: passo 4, immagine 3 di 3
    • Mark your measurements on both ends of your new weather treated wood using a measuring tape and a pencil.
    • For the best results, use a ruler to connect your marks into a straight line.
  5. How to Fix Broken Porch Entry Stairs: passo 5, immagine 1 di 1
    • Place the new piece of wood onto the end of a sturdy table.
    • Make sure the marked end is hanging off the edge by at least a foot.
  6. How to Fix Broken Porch Entry Stairs: passo 6, immagine 1 di 1
    • Use a circular saw to cut across the straight line marked on the new piece of wood.
    • Make sure the wood is secure by holding the end resting on the table the entire time.
    • Safety glasses should be worn during this step.
  7. How to Fix Broken Porch Entry Stairs: passo 7, immagine 1 di 2 How to Fix Broken Porch Entry Stairs: passo 7, immagine 2 di 2
    • Place the new piece of wood (riser) on the steps to ensure that it fits.
    • Use a leveler to make sure that it is level.
  8. How to Fix Broken Porch Entry Stairs: passo 8, immagine 1 di 3 How to Fix Broken Porch Entry Stairs: passo 8, immagine 2 di 3 How to Fix Broken Porch Entry Stairs: passo 8, immagine 3 di 3
    • Secure your wood piece (riser) into place using a drill and galvanized screws.
    • Create two pilot holes with the correct drill bit.
    • Secure the wood (riser) into place by drilling 2" galvanized Phillips head screws into the pilot holes.
  9. How to Fix Broken Porch Entry Stairs: passo 9, immagine 1 di 1
    • Make sure your wood piece (tread) fits into place and is level.
    • For the most accurate results, it is important to use a large level.
  10. How to Fix Broken Porch Entry Stairs: passo 10, immagine 1 di 3 How to Fix Broken Porch Entry Stairs: passo 10, immagine 2 di 3 How to Fix Broken Porch Entry Stairs: passo 10, immagine 3 di 3
    • Secure your wood piece (tread) into place using a drill and galvanized screws.
    • Create three pilot holes with the correct drill bit.
    • Secure the wood (tread) into place by drilling 2" galvanized Phillips head screws into the pilot holes.
  11. How to Fix Broken Porch Entry Stairs: passo 11, immagine 1 di 1
    • Repeat steps 8-10 for the remaining stairs.
    • For the best results, follow this guide thoroughly for each stair.
Conclusione
To reassemble your old stairs, follow these instructions in reverse order.
0 Commenti
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 5
Ultimi 7 Giorni: 33
Ultimi 30 Giorni: 118
Tutti i Tempi: 8,278
