Salta al contenuto principale
How to Fix A Warped Frisbee Disc
Cosa ti serve
  1. How to Fix A Warped Frisbee Disc, How to Fix A Warped Frisbee Disc: passo 1, immagine 1 di 2 How to Fix A Warped Frisbee Disc, How to Fix A Warped Frisbee Disc: passo 1, immagine 2 di 2
    • Place the frisbee disc on a flat surface with the concave side facing up. Lay a towel down flat over the frisbee.
  2. How to Fix A Warped Frisbee Disc: passo 2, immagine 1 di 1
    • Take the bowl and fill halfway full with water. Microwave until water is boiling.
    • The bowl will be hot, so handle it with care.
  3. How to Fix A Warped Frisbee Disc: passo 3, immagine 1 di 1
    • Take the bowl with boiling water and place it on top of the frisbee and the towel.
  4. How to Fix A Warped Frisbee Disc: passo 4, immagine 1 di 1
    • Add a textbook as a weight to sit on top of the bowl.
    • Let everything sit for 1 hour
  5. How to Fix A Warped Frisbee Disc: passo 5, immagine 1 di 1
    • Remove any weights, the bowl, and the towel. Check to see if the disc is still warped.
    • If it is still warped repeat this process one more time.
Conclusione
The time taken to fix the warping on your frisbee may vary based on how thick the plastic is.
Altre 2 persone hanno completato questa guida.
Cal Poly, Team 30-5, Green Spring 2015 Membro di Cal Poly, Team 30-5, Green Spring 2015
CPSU-GREEN-S15S30G5
5 Membri
32 Guide realizzate
0 Commenti
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 3
Ultimi 7 Giorni: 23
Ultimi 30 Giorni: 84
Tutti i Tempi: 9,695
