Salta al contenuto principale
How to Factory Reset an iPhone
  1. How to Factory Reset an iPhone, Navigate to the Settings Menu.: passo 1, immagine 1 di 3 How to Factory Reset an iPhone, Navigate to the Settings Menu.: passo 1, immagine 2 di 3 How to Factory Reset an iPhone, Navigate to the Settings Menu.: passo 1, immagine 3 di 3
    • Select the Settings App.
    • If you are unsure where your Settings App is, swipe all the way to the left and use the Search function to pull it up for you.
  2. How to Factory Reset an iPhone, Find Reset in Settings: passo 2, immagine 1 di 2 How to Factory Reset an iPhone, Find Reset in Settings: passo 2, immagine 2 di 2
    • Select General. It will likely be along the bottom edge of the first screen.
    • Scroll to the bottom of the following menu. Tap the Reset option. Depending on the version of iOS your phone is running it may alternatively read Transfer or Reset iPhone.
  3. How to Factory Reset an iPhone, Reset the iPhone: passo 3, immagine 1 di 3 How to Factory Reset an iPhone, Reset the iPhone: passo 3, immagine 2 di 3 How to Factory Reset an iPhone, Reset the iPhone: passo 3, immagine 3 di 3
    • Select the Erase All Content and Settings option.
    • The iPhone will confirm what information will be removed during this process. Click Continue at the bottom of the screen.
    • It will confirm one final time that you want to Erase it. It may ask for your Apple ID password to authenticate.
  4. How to Factory Reset an iPhone, Wait: passo 4, immagine 1 di 1
    • The phone will restart to an Apple logo. A progress bar will appear and fill as the the phone removes data and reinstalls the Operating System.
    • It may restart a few times during the process, or appear to be off for longer than usual between restarts.
    • After patiently waiting, the device will restart to the Setup Assistant allowing you to start configuration from scratch or someone else to do the same.
Conclusione
The iPhone Setup Assistant will walk you through reactivating and configuring your device. If this reset was done to rule out a software problem, restore your data later. Be sure your issue is resolved without all the additional apps, data and settings changes.
Altre 6 persone hanno completato questa guida.
Alisha C
Membro da: 12/04/20
33.460 Reputazione
5 Guide realizzate
LGBTQ Technicians Membro di LGBTQ Technicians
Community
15 Membri
52 Guide realizzate
0 Commenti
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 1
Ultimi 7 Giorni: 16
Ultimi 30 Giorni: 70
Tutti i Tempi: 1,107
