Salta al contenuto principale
How to Dye a Used Shirt
Cosa ti serve
  1. How to Dye a Used Shirt, How to Dye a Used Shirt: passo 1, immagine 1 di 1
    • The dye used for this guide is Rit DyeMore.
    • Buy the product and make sure to read the instructions on the bottle.
    • Weigh your shirt & follow instructions on the bottle according to weight to determine how much dye is needed.
    • Pre-wash your clothing item and prepare your materials and work area.
  2. How to Dye a Used Shirt: passo 2, immagine 1 di 1
    • Add enough water in a stainless steel pot to let the clothing item move freely.
  3. How to Dye a Used Shirt: passo 3, immagine 1 di 1
    • Add 1 tsp of dish detergent to the pot.
  4. How to Dye a Used Shirt: passo 4, immagine 1 di 1
    • Cover the pot and let the water reach close to boiling temperature ~200 degrees Fahrenheit.
  5. How to Dye a Used Shirt: passo 5, immagine 1 di 1
    • Add the desired amount of dye that was measured via the bottle to the water and turn the stove top temperature to simmer.
  6. How to Dye a Used Shirt: passo 6, immagine 1 di 2 How to Dye a Used Shirt: passo 6, immagine 2 di 2
    • Place wet clothing item in the solution.
    • Stir slowly for 10 minutes.
  7. How to Dye a Used Shirt: passo 7, immagine 1 di 2 How to Dye a Used Shirt: passo 7, immagine 2 di 2
    • After the desired color is achieved, remove the item from the solution.
    • Rinse the clothing item with warm water.
    • Gradually use cooler water until the water runs clear.
    • Wash the clothing item in warm water.
    • Dry and enjoy your new clothing item!
Conclusione
Enjoy your new wardrobe!
Altre 2 persone hanno completato questa guida.
0 Commenti
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 2
Ultimi 7 Giorni: 14
Ultimi 30 Giorni: 30
Tutti i Tempi: 463
