Salta al contenuto principale
How to Disassemble an OXO Container Lid for Cleaning
Cosa ti serve
  1. How to Disassemble an OXO Container Lid for Cleaning, How to Disassemble an OXO Container Lid for Cleaning: passo 1, immagine 1 di 2 How to Disassemble an OXO Container Lid for Cleaning, How to Disassemble an OXO Container Lid for Cleaning: passo 1, immagine 2 di 2
    • Twist the bottom piece off by following the directions displayed on the lid.
    • Once inside, remove the outer layer seal from the lid by pulling it straight up.
  2. How to Disassemble an OXO Container Lid for Cleaning: passo 2, immagine 1 di 3 How to Disassemble an OXO Container Lid for Cleaning: passo 2, immagine 2 di 3 How to Disassemble an OXO Container Lid for Cleaning: passo 2, immagine 3 di 3
    • Flip the lid so the button faces up. Then remove the button from the base of the lid.
    • This requires more added force.
    • Separate the interior prongs.
  3. How to Disassemble an OXO Container Lid for Cleaning: passo 3, immagine 1 di 2 How to Disassemble an OXO Container Lid for Cleaning: passo 3, immagine 2 di 2
    • After separating the prongs, the spring and the circular spring cap will separate from the square frame with little force.
    • With some force, remove the two prongs from the base of the lid by snapping them out of the bracket. Be careful not to break the bracket's small prongs.
    • The disassembled parts can now be cleaned with warm, soapy water.
  4. How to Disassemble an OXO Container Lid for Cleaning: passo 4, immagine 1 di 2 How to Disassemble an OXO Container Lid for Cleaning: passo 4, immagine 2 di 2
    • To reassemble the lid, start by connecting the outer layer piece with the base piece. Grooves in the parts will only allow them to be connected in the correct way.
    • Place the spring in the center of the lid within the circular outline.
  5. How to Disassemble an OXO Container Lid for Cleaning: passo 5, immagine 1 di 1
    • Take the small interior circle and place it on top of the spring.
    • Use force to push this piece down. Make sure the slots align.
    • This piece will not stay in place on its own. Flip the lid over and keep it on a flat surface to prevent the spring from releasing.
  6. How to Disassemble an OXO Container Lid for Cleaning: passo 6, immagine 1 di 2 How to Disassemble an OXO Container Lid for Cleaning: passo 6, immagine 2 di 2
    • Reattach the two prongs to the lid.
    • Intertwine the two prongs together.
    • The spring should now be firmly held in place.
  7. How to Disassemble an OXO Container Lid for Cleaning: passo 7, immagine 1 di 2 How to Disassemble an OXO Container Lid for Cleaning: passo 7, immagine 2 di 2
    • Twist the bottom piece back on the lid.
    • Reattach the button to the center of the lid.
Linea Traguardo
Altre 2 persone hanno completato questa guida.
Lorna Lauro
Membro da: 04/20/22
187 Reputazione
1 Guida realizzata
Un commento
Excellent guide, a set I got came with the metal pins of the prongs unseated from their holes, causing the lid to operate incorrectly. I was able to re-seat them and get the lid working with the help of this.
Stefan Rust - Replica
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 16
Ultimi 7 Giorni: 75
Ultimi 30 Giorni: 309
Tutti i Tempi: 12,020
