Salta al contenuto principale
How to Darn a Sock
Cosa ti serve
  1. How to Darn a Sock, How to Darn a Sock: passo 1, immagine 1 di 2 How to Darn a Sock, How to Darn a Sock: passo 1, immagine 2 di 2
    • Insert a darning egg (or substitute object) into the sock until the hole is stretched out.
  2. How to Darn a Sock: passo 2, immagine 1 di 2 How to Darn a Sock: passo 2, immagine 2 di 2
    • Sew a running stitch around the hole to reinforce it.
    • To make a running stitch, move your needle in and out of the sock a fixed distance apart.
    • The needle is sharp; use caution and avoid poking your hand.
  3. How to Darn a Sock: passo 3, immagine 1 di 2 How to Darn a Sock: passo 3, immagine 2 di 2
    • Start a stitch from one side of the hole, about ½” to ⅛” away. Connect one side of the hole to the other using the thread.
    • Run parallel stitches until the hole is fully covered.
  4. How to Darn a Sock: passo 4, immagine 1 di 2 How to Darn a Sock: passo 4, immagine 2 di 2
    • Rotate your sock 90 degrees, then repeat step 4 to create a patch.
  5. How to Darn a Sock: passo 5, immagine 1 di 2 How to Darn a Sock: passo 5, immagine 2 di 2
    • Weave the extra thread into the sock's fabric, then cut the needle away from the thread.
Linea Traguardo
justinHo910
Membro da: 10/24/23
121 Reputazione
1 Guida realizzata
0 Commenti
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 2
Ultimi 7 Giorni: 10
Ultimi 30 Giorni: 47
Tutti i Tempi: 243
