Salta al contenuto principale
How to Create a Custom Cotton Swab
Cosa ti serve
  1. How to Create a Custom Cotton Swab, Find a tool: passo 1, immagine 1 di 3 How to Create a Custom Cotton Swab, Find a tool: passo 1, immagine 2 di 3 How to Create a Custom Cotton Swab, Find a tool: passo 1, immagine 3 di 3
    • Find a small object with a pointed end, such as:
    • A toothpick
    • A spudger
    • The end of a flossing pick
    • Avoid metal objects, like paperclips, or anything brittle that might break off in the charging port.
  2. How to Create a Custom Cotton Swab, Separate the cotton: passo 2, immagine 1 di 3 How to Create a Custom Cotton Swab, Separate the cotton: passo 2, immagine 2 di 3 How to Create a Custom Cotton Swab, Separate the cotton: passo 2, immagine 3 di 3
    • Pull off a small part of a cotton ball.
    • You only need a small amount of cotton—enough to create a thin layer around your tool.
  3. How to Create a Custom Cotton Swab, Apply the cotton: passo 3, immagine 1 di 3 How to Create a Custom Cotton Swab, Apply the cotton: passo 3, immagine 2 di 3 How to Create a Custom Cotton Swab, Apply the cotton: passo 3, immagine 3 di 3
    • Wrap the cotton around the tip of your tool.
    • Roll the cotton between your fingers to compress it into a thin layer.
  4. How to Create a Custom Cotton Swab, Remove any excess cotton: passo 4, immagine 1 di 3 How to Create a Custom Cotton Swab, Remove any excess cotton: passo 4, immagine 2 di 3 How to Create a Custom Cotton Swab, Remove any excess cotton: passo 4, immagine 3 di 3
    • Test your cotton swab on your device to see if it fits.
    • If your swab doesn't fit, remove any excess cotton and reroll your cotton so it's compressed and tight along the tip of your tool.
    • If the swab still doesn't fit, you may need to find a different tool altogether.
    • Your custom cotton swab is ready! Return to where you left off in your guide.
Conclusione
For other general electronics skills guides, click here.
Altre 3 persone hanno completato questa guida.
Alex Diaz-Kokaisl
Membro da: 01/16/22
125.789 Reputazione
592 Guide realizzate
iFixit Membro di iFixit
Staff
137 Membri
17.524 Guide realizzate
0 Commenti
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 8
Ultimi 7 Giorni: 52
Ultimi 30 Giorni: 221
Tutti i Tempi: 1,008
