Salta al contenuto principale
How to Clean Corroded Battery Terminals
Cosa ti serve
  1. How to Clean Corroded Battery Terminals, Safety precautions: passo 1, immagine 1 di 1
    • Wear gloves to protect your hands from the corrosion—it's a skin irritant.
    • If your device still works, power it down completely before starting.
  2. How to Clean Corroded Battery Terminals, Remove the batteries: passo 2, immagine 1 di 3 How to Clean Corroded Battery Terminals, Remove the batteries: passo 2, immagine 2 di 3 How to Clean Corroded Battery Terminals, Remove the batteries: passo 2, immagine 3 di 3
  3. How to Clean Corroded Battery Terminals, Remove big chunks of corrosion: passo 3, immagine 1 di 3 How to Clean Corroded Battery Terminals, Remove big chunks of corrosion: passo 3, immagine 2 di 3 How to Clean Corroded Battery Terminals, Remove big chunks of corrosion: passo 3, immagine 3 di 3
    • Use a toothbrush to gently remove any bigger chunks of corrosion from the battery terminals and battery recess.
    • Use the point of a spudger to pick out any bits that are stuck.
    • Pick around the batteries, and not at the batteries themselves.
    • Flip your device over and gently shake out the loose corrosion and debris.
    • Dispose of the corrosion and debris in the trash.
  4. How to Clean Corroded Battery Terminals, Remove any stuck batteries: passo 4, immagine 1 di 2 How to Clean Corroded Battery Terminals, Remove any stuck batteries: passo 4, immagine 2 di 2
    • You should now be able to remove any batteries that were previously stuck.
    • Clean out the battery recess with a toothbrush.
  5. How to Clean Corroded Battery Terminals, Clean the terminals: passo 5, immagine 1 di 3 How to Clean Corroded Battery Terminals, Clean the terminals: passo 5, immagine 2 di 3 How to Clean Corroded Battery Terminals, Clean the terminals: passo 5, immagine 3 di 3
    • Alkaline batteries contain a base, which is what corrosion is made of. An acid like white vinegar or lemon juice will neutralize this base.
    • Lightly dip a cotton swab in white vinegar or lemon juice.
    • Don't soak the cotton swab. Only use a small amount of liquid at a time.
    • Gently rub the battery terminals with the cotton swab to dissolve and remove the corrosion.
    • The corrosion may fizz and bubble. Don't worry, this is normal.
    • Continue this process until there's no corrosion on the terminals.
  6. How to Clean Corroded Battery Terminals: passo 6, immagine 1 di 3 How to Clean Corroded Battery Terminals: passo 6, immagine 2 di 3 How to Clean Corroded Battery Terminals: passo 6, immagine 3 di 3
    Attrezzo utilizzato in questo passaggio:
    Microfiber Cleaning Cloths
    $3.99
    Compra
    • Isopropyl alcohol will remove any residue left from the previous step.
    • Lightly dip a cotton swab in highly-concentrated isopropyl alcohol (over 90%).
    • Gently rub the battery terminals with the cotton swap to remove any remaining residue from the previous step.
    • Wipe the residue away with a microfiber or lint-free cloth.
    • Repeat this process until the terminals are completely clean.
    • Wait two minutes to allow any residual alcohol to evaporate.
  7. How to Clean Corroded Battery Terminals, Install new batteries: passo 7, immagine 1 di 3 How to Clean Corroded Battery Terminals, Install new batteries: passo 7, immagine 2 di 3 How to Clean Corroded Battery Terminals, Install new batteries: passo 7, immagine 3 di 3
Conclusione
Cleaning didn’t go as planned? Ask our Answers community for help.
For other electronics skills, click here.
Altre 2 persone hanno completato questa guida.
Spencer Day
Membro da: 09/14/22
58.593 Reputazione
430 Guide realizzate
iFixit Membro di iFixit
Staff
137 Membri
17.524 Guide realizzate
0 Commenti
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 60
Ultimi 7 Giorni: 354
Ultimi 30 Giorni: 1,354
Tutti i Tempi: 6,040
