Salta al contenuto principale
How to Add a Hole to a Belt
Cosa ti serve
  1. How to Add a Hole to a Belt, How to Add a Hole to a Belt: passo 1, immagine 1 di 1
    • Wrap the belt around yourself.
    • Mark with a pen, pencil, or marker where the hole should be placed.
  2. How to Add a Hole to a Belt: passo 2, immagine 1 di 2 How to Add a Hole to a Belt: passo 2, immagine 2 di 2
    • Use a tape measure to center the hole in the middle of the belt.
    • Make sure the hole is in line with the previous hole as well.
  3. How to Add a Hole to a Belt: passo 3, immagine 1 di 1
    • Grab a hand drill with a circular bit similar to the size of the current belt holes.
    • For reference, a 5/32 bit was used here.
  4. How to Add a Hole to a Belt: passo 4, immagine 1 di 2 How to Add a Hole to a Belt: passo 4, immagine 2 di 2
    • Place the belt over a scrap piece of wood or on a material that can be drilled on.
  5. How to Add a Hole to a Belt: passo 5, immagine 1 di 2 How to Add a Hole to a Belt: passo 5, immagine 2 di 2
    • Drill all the way through the belt where it has been marked.
  6. How to Add a Hole to a Belt: passo 6, immagine 1 di 2 How to Add a Hole to a Belt: passo 6, immagine 2 di 2
    • Move the drill up and down a few times in place to ensure the hole is smooth around the edges.
    • Be sure the belt buckle fits in the new hole.
Conclusione
After you complete the final step to your liking the fix is done.
Alexa Velazquez
Membro da: 03/22/21
133 Reputazione
1 Guida realizzata
0 Commenti
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 10
Ultimi 30 Giorni: 36
Tutti i Tempi: 1,322
